[Bio] / FigKernelPackages / SeedEnv.pm Repository:
Log of /FigKernelPackages/SeedEnv.pm
Wed Dec 16 21:40:28 2009 UTC (10 years ago) by parrello
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.2: +1 -4 lines
Added ANNOserver. Removed deprecated servers.
Fri Dec 11 21:50:13 2009 UTC (10 years ago) by parrello
Tue Nov 24 20:53:31 2009 UTC (10 years ago) by olson
Diff to selected 1.3
new one-use seed server include file
