[Bio] / FigKernelPackages / SeedEnv.pm Repository:
Log of /FigKernelPackages/SeedEnv.pm
Mon Mar 24 21:25:57 2014 UTC (5 years, 8 months ago) by olson
Changes since 1.4: +4 -1 lines
Make conditional on existence of ModelSEED.
Mon Feb 28 21:52:08 2011 UTC (8 years, 9 months ago) by olson
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0928
Use new path to FBAModelSerer
Wed Dec 16 21:40:28 2009 UTC (9 years, 11 months ago) by parrello
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.2: +1 -4 lines
Added ANNOserver. Removed deprecated servers.
Fri Dec 11 21:50:13 2009 UTC (9 years, 11 months ago) by parrello
Tue Nov 24 20:53:31 2009 UTC (10 years ago) by olson
new one-use seed server include file
