[Bio] / FigKernelPackages / SeedAware.pm Repository:
Log of /FigKernelPackages/SeedAware.pm
Thu Sep 16 23:51:21 2010 UTC (9 years, 2 months ago) by golsen
CVS Tags: rast_rel_2010_0928, rast_rel_2010_1206
Minor change in temporary file name code.
Mon Aug 30 17:40:04 2010 UTC (9 years, 2 months ago) by olson
Changes since 1.3: +33 -0 lines
Bah. Can't use -| on windows, so there, require IPC::Run and use its redirection.
Mon Aug 23 18:33:11 2010 UTC (9 years, 2 months ago) by olson
CVS Tags: rast_rel_2010_0827
Changes since 1.2: +5 -3 lines
More FS_RAST modes & supporting code for SAS use.
Tue Aug 17 00:04:20 2010 UTC (9 years, 3 months ago) by golsen
Fix the description of new_file_name() to match the parameter list.
Sun Aug 15 23:35:49 2010 UTC (9 years, 3 months ago) by golsen
A package of functions for handling functions in SEED and non-SEED
environments.
Also includes functions for running subprocesses without a shell.
