[Bio] / FigKernelPackages / ScriptThing.pm Repository:
Log of /FigKernelPackages/ScriptThing.pm
Wed Aug 11 18:06:10 2010 UTC (9 years, 6 months ago) by parrello
Changes since 1.6: +12 -3 lines
New version of CommentHash that's column-aware.
Tue Aug 10 17:51:20 2010 UTC (9 years, 6 months ago) by parrello
Changes since 1.5: +25 -11 lines
Added support for putting input IDs on the command line.
Wed Jul 21 18:55:49 2010 UTC (9 years, 6 months ago) by parrello
Changes since 1.4: +97 -15 lines
Added support for the signature genes script.
Tue Jul 20 21:10:32 2010 UTC (9 years, 7 months ago) by parrello
Added stuff to support new command-line scripts.
Tue Jan 5 17:31:22 2010 UTC (10 years, 1 month ago) by parrello
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.2: +18 -5 lines
Added a column parameter to GetBatch.
Thu Dec 17 22:20:43 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.1: +20 -0 lines
Added debugging assistance for STDIN.
Thu Oct 29 18:26:59 2009 UTC (10 years, 3 months ago) by parrello
Final server updates.
