[Bio] / FigKernelPackages / Scenario.pm Repository:
Log of /FigKernelPackages/Scenario.pm
Fri Oct 30 18:59:07 2009 UTC (10 years ago) by dejongh
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.8: +142 -65 lines
new methods
Thu Apr 2 01:10:33 2009 UTC (10 years, 7 months ago) by parrello
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.7: +1 -0 lines
Added a line to suppress spurious warnings.
Thu Nov 13 21:55:06 2008 UTC (11 years ago) by dejongh
CVS Tags: rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26
Changes since 1.6: +2 -13 lines
Move get_hope_reactions_for_genome to model.pm
Wed Nov 12 18:26:31 2008 UTC (11 years ago) by dejongh
Changes since 1.5: +23 -5 lines
switch to scenario_directory
Wed Nov 14 19:43:45 2007 UTC (12 years ago) by dejongh
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.4: +22 -0 lines
Added getter/setter for path_info
Fri Nov 2 19:12:58 2007 UTC (12 years ago) by dejongh
Hope College updates
Mon Jul 23 20:29:55 2007 UTC (12 years, 3 months ago) by formsma
Changes since 1.2: +1 -2 lines
Fixed error for RAST server in which model directory was incorrectly handled - Kevin
Fri Jul 20 15:00:07 2007 UTC (12 years, 4 months ago) by formsma
Changes since 1.1: +14 -2 lines
Fixed filehandles to add compatability with RAST. This means using FIGV and making sure
we use $fig->model_directory() instead of $FIG_Config::var/Models - Kevin
Tue Jul 17 16:00:13 2007 UTC (12 years, 4 months ago) by formsma
First revision of Scenario.pm which is used for reading scenario data and provides functionality for model testing and creation - Kevin
