[Bio] / FigKernelPackages / SameFunc.pm Repository:
Log of /FigKernelPackages/SameFunc.pm
Sat Dec 1 16:46:53 2007 UTC (12 years ago) by overbeek
Diff to previous 1.16
fix to SameFunc.pm
Mon Sep 25 19:19:58 2006 UTC (13 years, 2 months ago) by overbeek
Changes since 1.15: +0 -1 lines
Removed whitespace rule that conflicts with later rule. -- /gdp
Sat Sep 2 12:37:00 2006 UTC (13 years, 3 months ago) by overbeek
Changes since 1.14: +64 -22 lines
fix minor error in find_genes_based_on_neighbors
Tue Jul 25 22:03:01 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.13: +3 -2 lines
Moved EC-number removal to before punctuation-character removal. -- /gdp
Tue Jul 25 21:25:04 2006 UTC (13 years, 4 months ago) by overbeek
Fixed greedy-match bug in ribosomal protein rule. -- /gdp
Tue Jul 25 21:12:09 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.11: +3 -1 lines
Ribosomal Protein Rule. TD
Tue Jul 25 20:39:11 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.10: +113 -0 lines
Added SameFuncWhy. TD
Tue May 30 02:50:58 2006 UTC (13 years, 6 months ago) by overbeek
Changes since 1.9: +6 -2 lines
fixs to rapid propagation
Changes since 1.8: +17 -0 lines
Added license words.
Wed Nov 2 22:00:09 2005 UTC (14 years, 1 month ago) by parrello
CVS Tags: caBIG-00-00-00
Changes since 1.7: +3 -1 lines
Changed to remove deprecated use of implicit split to @_.
Wed Aug 17 12:24:43 2005 UTC (14 years, 3 months ago) by overbeek
CVS Tags: caBIG-dataload-0
Changes since 1.6: +7 -6 lines
fixes to automated assignments
Fri Apr 29 16:43:29 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.5: +14 -7 lines
add assign_to_close_strains
Mon Aug 16 22:10:55 2004 UTC (15 years, 3 months ago) by overbeek
straighten out FIG.pm
Thu Aug 5 21:53:32 2004 UTC (15 years, 4 months ago) by overbeek
Changes since 1.3: +7 -1 lines
minor improvements to automated assignments
Fri Jun 4 22:48:49 2004 UTC (15 years, 6 months ago) by overbeek
handle multifunctional functions in same_func
Sat Apr 24 15:02:08 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.1: +43 -44 lines
tools for McCune to build expert automated assignments
Mon Dec 1 16:54:26 2003 UTC (16 years ago) by efrank
Branch point for: initial
