[Bio] / FigKernelPackages / SSserver.pm Repository:
Log of /FigKernelPackages/SSserver.pm
Links to mgrast_dev_02212011: (view) (download) (as text) (annotate)
Thu Dec 17 20:48:21 2009 UTC (10 years, 1 month ago) by parrello
Changes since 1.16: +0 -4 lines
Diff to previous 1.16
Removed from the SAS distribution.
Revision 1.16 - (view) (download) (as text) (annotate) - [selected]
Tue Dec 1 23:43:22 2009 UTC (10 years, 1 month ago) by parrello
Changed to use the default URL if an empty string is specified, for compatibility with some of the scripts.
Mon Nov 30 11:45:22 2009 UTC (10 years, 1 month ago) by parrello
Changes since 1.14: +5 -245 lines
Diff to previous 1.14 , to selected 1.16
Converted to use ClientThing.
Wed Nov 25 20:22:42 2009 UTC (10 years, 1 month ago) by olson
Changes since 1.13: +40 -8 lines
Diff to previous 1.13 , to selected 1.16
add retry logic
Fri Nov 6 22:54:13 2009 UTC (10 years, 2 months ago) by olson
Changes since 1.12: +1 -0 lines
Diff to previous 1.12 , to selected 1.16
reset client timeouts here too
Thu Nov 5 20:59:01 2009 UTC (10 years, 2 months ago) by parrello
Diff to previous 1.11 , to selected 1.16
Restored missing URLs.
Tue Nov 3 21:20:07 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.10: +141 -44 lines
Diff to previous 1.10 , to selected 1.16
Error handling restructure.
Thu Aug 27 19:46:36 2009 UTC (10 years, 4 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Changes since 1.9: +161 -58 lines
Diff to previous 1.9 , to selected 1.16
Converted subsystem server to new technology.
Mon Aug 3 21:31:42 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.8: +11 -12 lines
Diff to previous 1.8 , to selected 1.16
Updated to Sapling Server for Berkeley.
Wed Jul 15 23:37:46 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.7: +8 -10 lines
Diff to previous 1.7 , to selected 1.16
Updates for operon pipeline.
Tue Jun 30 19:38:32 2009 UTC (10 years, 6 months ago) by disz
CVS Tags: rast_rel_2009_07_09
Changes since 1.6: +5 -0 lines
Diff to previous 1.6 , to selected 1.16
pegs_implementing_roles
Wed Jun 24 16:24:24 2009 UTC (10 years, 7 months ago) by olson
Changes since 1.5: +4 -2 lines
Diff to previous 1.5 , to selected 1.16
switch to the servers.nmpdr.org name
Fri Jun 19 17:47:59 2009 UTC (10 years, 7 months ago) by disz
Changes since 1.4: +8 -3 lines
Diff to previous 1.4 , to selected 1.16
This is Terry's version that works
Fri Jun 19 17:30:02 2009 UTC (10 years, 7 months ago) by olson
Diff to previous 1.3 , to selected 1.16
server fixes
Mon May 11 20:36:35 2009 UTC (10 years, 8 months ago) by olson
CVS Tags: rast_rel_2009_05_18
Diff to previous 1.2 , to selected 1.16
fixes to use the canonical server url
Mon May 11 18:37:24 2009 UTC (10 years, 8 months ago) by disz
Diff to previous 1.1 , to selected 1.16
new all families commabd
Fri May 8 19:16:17 2009 UTC (10 years, 8 months ago) by disz
Diff to selected 1.16
Client side package to access the subsystem_server
