[Bio] / FigKernelPackages / SSU_rRNA_reps.pm Repository:
Log of /FigKernelPackages/SSU_rRNA_reps.pm
Links to rast_rel_2011_0119: (view) (download) (as text) (annotate)
Sat Aug 14 21:32:19 2010 UTC (9 years, 9 months ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, myrast_33, myrast_rel40, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Adjust end of one reference sequence by padding it slightly.
Tue Jan 19 01:55:09 2010 UTC (10 years, 4 months ago) by golsen
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Update to the variable names (for more universal application).
Thu Feb 5 14:50:43 2009 UTC (11 years, 4 months ago) by overbeek
CVS Tags: rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
fixes to support search for rRNAs
