[Bio] / FigKernelPackages / SS.pm Repository:
Log of /FigKernelPackages/SS.pm
Mon Dec 7 21:02:09 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.12: +23 -23 lines
More documentation cleanup.
Mon Dec 7 19:28:50 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.11: +114 -31 lines
More conversions.
Sun Dec 6 18:21:07 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.10: +128 -17 lines
Added new subsystem methods.
Fri Dec 4 20:12:14 2009 UTC (10 years, 2 months ago) by disz
Changes since 1.9: +7 -1 lines
changed doc to say XXserver->new() insetad of XX->new
Fri Dec 4 18:48:32 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.8: +71 -20 lines
Converted is_in_subsystem_with to new format.
Wed Dec 2 22:14:40 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.7: +65 -14 lines
Cleaned up "is_in_subsystem".
Wed Dec 2 16:59:06 2009 UTC (10 years, 2 months ago) by disz
fixed type in the doc
Wed Nov 25 22:37:40 2009 UTC (10 years, 2 months ago) by parrello
Changes since 1.5: +9 -6 lines
Fixed pegs_in_subsystems to fail gracefully if the subsystem does not exist.
Tue Nov 3 21:20:07 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.4: +24 -0 lines
Error handling restructure.
Tue Oct 20 17:47:47 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.3: +8 -3 lines
Added "pegs_in_subsystems" as a synonym of "pegs_in_subsystem".
Tue Oct 13 19:23:49 2009 UTC (10 years, 4 months ago) by overbeek
Changes since 1.2: +12 -1 lines
distinguish assignments and functional roles
Thu Oct 1 23:33:22 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.1: +6 -7 lines
Fixed documentation for metabolic reconstruction. Fixed to allow specification of a functional role with no associated ID.
Thu Aug 27 19:46:36 2009 UTC (10 years, 5 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Converted subsystem server to new technology.
