Log of /FigKernelPackages/SFXlate.pm
Parent Directory
Revision
1.119 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Jul 15 23:39:01 2009 UTC (10 years, 5 months ago) by
parrello
Branch:
MAIN
CVS Tags:
HEAD,
mgrast_dev_02212011,
mgrast_dev_02222011,
mgrast_dev_03252011,
mgrast_dev_03312011,
mgrast_dev_04012011,
mgrast_dev_04052011,
mgrast_dev_04082011,
mgrast_dev_04132011,
mgrast_dev_05262011,
mgrast_dev_06072011,
mgrast_dev_08022011,
mgrast_dev_08112011,
mgrast_dev_10262011,
mgrast_dev_12152011,
mgrast_release_3_0,
mgrast_release_3_0_1,
mgrast_release_3_0_2,
mgrast_release_3_0_3,
mgrast_release_3_0_4,
mgrast_release_3_1_0,
mgrast_release_3_1_1,
mgrast_release_3_1_2,
mgrast_version_3_2,
myrast_33,
myrast_rel40,
rast_rel_2009_0925,
rast_rel_2010_0118,
rast_rel_2010_0526,
rast_rel_2010_0827,
rast_rel_2010_0928,
rast_rel_2010_1206,
rast_rel_2011_0119,
rast_rel_2011_0928,
rast_rel_2014_0729,
rast_rel_2014_0912
Changes since
1.118: +35 -0 lines
Diff to
previous 1.118
Added "families_containing_peg".
Revision
1.105 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Sep 3 20:32:24 2008 UTC (11 years, 3 months ago) by
parrello
Branch:
MAIN
Changes since
1.104: +53 -15 lines
Diff to
previous 1.104
Added subsystem_version and some clearinghouse methods. Fixed to fail gracefully when the attribute server is down.
Revision
1.101 -
view)
download)
as text)
annotate)
[select for diffs]
Tue Feb 5 02:09:34 2008 UTC (11 years, 10 months ago) by
parrello
Branch:
MAIN
Changes since
1.100: +22 -2 lines
Diff to
previous 1.100
Fixed a compiler warnings. Added support for the SEED database host being different from the Sprout database host.
Revision
1.100 -
view)
download)
as text)
annotate)
[select for diffs]
Tue Jan 8 21:14:59 2008 UTC (11 years, 11 months ago) by
parrello
Branch:
MAIN
Changes since
1.99: +12 -3 lines
Diff to
previous 1.99
Changed to allow undef for the parameters in genome_of and is_genome. FIG.pm allows this, and chromosomal_clusters.cgi depends on it.
Revision
1.98 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Dec 6 13:55:57 2007 UTC (12 years ago) by
parrello
Branch:
MAIN
Changes since
1.97: +522 -141 lines
Diff to
previous 1.97
Changed POD format for better compatability with Wiki. Added support for "genome_list", "contig_lengths", "get_genome_subsystem_count", "get_peg_keys", "all_subsystem_classifications", "subsystems_for"pegs", "run", "run_gathering_output", "is_locked_fid", and a partridge in a pear tree.
Revision
1.85 -
view)
download)
as text)
annotate)
[select for diffs]
Tue Oct 17 11:36:37 2006 UTC (13 years, 2 months ago) by
parrello
Branch:
MAIN
Changes since
1.84: +2 -4 lines
Diff to
previous 1.84
Changed translation check to return TRUE for any real feature. Previously, it returned FALSE for features without protein translations, causing the protein page to fail.
Revision
1.55 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Dec 8 18:13:02 2005 UTC (14 years ago) by
parrello
Branch:
MAIN
Changes since
1.54: +25 -14 lines
Diff to
previous 1.54
Added a method that can be used to determine whether the data is being taken from SEED or NMPDR.
Changed the "FIG" method to work like the same method in FIG.pm.
Revision
1.54 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Dec 7 19:38:22 2005 UTC (14 years ago) by
golsen
Branch:
MAIN
Changes since
1.53: +1 -1 lines
Diff to
previous 1.53
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one. Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
Revision
1.46 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Nov 2 22:07:38 2005 UTC (14 years, 1 month ago) by
parrello
Branch:
MAIN
Changes since
1.45: +240 -64 lines
Diff to
previous 1.45
Changed "cas_to_cid" to return an empty string if more than one compound has the same CAS ID. (This matches FIG functionality.)
Fixed spelling of "stiochiometry".
Implemented "catalyzes", "ec_to_maps", "displayable_reaction", "all_maps", "role_to_maps", "map_to_ecs", and "map_name".
Revision
1.44 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Oct 20 10:22:48 2005 UTC (14 years, 1 month ago) by
parrello
Branch:
MAIN
Changes since
1.43: +128 -12 lines
Diff to
previous 1.43
Added the first wave of KEGG-method analogs.
Changed "function_of" to behave more like the FIG method.
Revision
1.42 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Oct 13 15:27:54 2005 UTC (14 years, 2 months ago) by
parrello
Branch:
MAIN
Changes since
1.41: +11 -5 lines
Diff to
previous 1.41
Modified the "new_sprout_only" method to allow specification of the "noDBOpen" option. This allows it to be used in "LoadSproutTables".
Revision
1.40 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Oct 12 02:34:46 2005 UTC (14 years, 2 months ago) by
parrello
Branch:
MAIN
Changes since
1.39: +123 -29 lines
Diff to
previous 1.39
Added "compute_clusters" and "get_subsystem" methods for SFXlate so that it can be used in "UnvSubsys" as a FIG object replacement.
Fixed "coupling_and_evidence" to remove the bogus reflexive coupling. This helps it to function like the corresponding FIG method.
Added the "raw flag" to the feature_annotations method.
Fixed up some comments.
Revision
1.35 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Sep 1 09:33:46 2005 UTC (14 years, 3 months ago) by
parrello
Branch:
MAIN
Changes since
1.34: +7 -4 lines
Diff to
previous 1.34
Fixed a bug in the handling of subsystem roles. Fixed another bug in the handling of location strings.
Revision
1.24 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Jun 22 21:03:00 2005 UTC (14 years, 5 months ago) by
parrello
Branch:
MAIN
Changes since
1.23: +935 -143 lines
Diff to
previous 1.23
Replaced tabs with spaces to make indenting device-independent.
Added POD documentation.
Finished implementing the methods required by InterfaceRoutines.pm
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
