Links to HEAD: | (view) (download) (as text) (annotate) |
Links to rast_rel_2010_1206: | (view) (download) (as text) (annotate) |
Sticky Tag: |
Allow alternate forms of parameters to client-side modules.
Added support for using SAS_SERVER environment variable to configure the appropriate server.
Changed to use the default URL if an empty string is specified, for compatibility with some of the scripts.
The scripts are calling these with "url => ''" which makes them not pick up the default URL.
Error handling restructure.
Changed to allow specification of 'localhost" for the server URL. When this is done, the SAP module is called directly instead of remotely through the server.
Moved SAS-component flag above copyright text.
Changed handling of documentation URL.
Updated to Sapling Server for Berkeley.
Updates for operon pipeline.
Additional functionality for sapling server.
Finished up the Sapling server methods.
New Sapling server support.
MCS Webmaster | ViewVC Help |
Powered by ViewVC 1.0.3 |
