[Bio] / FigKernelPackages / SAPserver.pm Repository:
Log of /FigKernelPackages/SAPserver.pm
Mon Aug 9 13:46:06 2010 UTC (9 years, 4 months ago) by parrello
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Diff to previous 1.12 , to selected 1.1
Allow alternate forms of parameters to client-side modules.
Thu Jul 29 17:35:51 2010 UTC (9 years, 4 months ago) by parrello
Changes since 1.11: +2 -1 lines
Diff to previous 1.11 , to selected 1.1
Added support for using SAS_SERVER environment variable to configure the appropriate server.
Tue Dec 1 23:43:22 2009 UTC (10 years ago) by parrello
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Diff to previous 1.10 , to selected 1.1
Changed to use the default URL if an empty string is specified, for compatibility with some of the scripts.
Tue Dec 1 20:57:02 2009 UTC (10 years ago) by olson
Diff to previous 1.9 , to selected 1.1
The scripts are calling these with "url => ''" which makes them not pick up the default URL.
Tue Nov 3 21:20:07 2009 UTC (10 years, 1 month ago) by parrello
Changes since 1.8: +7 -140 lines
Diff to previous 1.8 , to selected 1.1
Error handling restructure.
Tue Sep 8 21:31:32 2009 UTC (10 years, 3 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Changes since 1.7: +48 -29 lines
Diff to previous 1.7 , to selected 1.1
Changed to allow specification of 'localhost" for the server URL. When this is done, the SAP module is called directly instead of remotely through the server.
Wed Aug 5 19:45:46 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.6: +2 -5 lines
Diff to previous 1.6 , to selected 1.1
Moved SAS-component flag above copyright text.
Tue Aug 4 18:41:56 2009 UTC (10 years, 4 months ago) by parrello
Changed handling of documentation URL.
Mon Aug 3 21:31:42 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.4: +40 -7 lines
Updated to Sapling Server for Berkeley.
Wed Jul 15 23:37:46 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.3: +5 -1 lines
Updates for operon pipeline.
Tue Jun 30 20:11:54 2009 UTC (10 years, 5 months ago) by parrello
CVS Tags: rast_rel_2009_07_09
Additional functionality for sapling server.
Thu Jun 18 01:29:19 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.1: +7 -7 lines
Finished up the Sapling server methods.
Tue Jun 16 16:37:23 2009 UTC (10 years, 5 months ago) by parrello
New Sapling server support.
