[Bio] / FigKernelPackages / SAPserver.pm Repository:
Log of /FigKernelPackages/SAPserver.pm
Tue Dec 1 23:43:22 2009 UTC (10 years ago) by parrello
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Changed to use the default URL if an empty string is specified, for compatibility with some of the scripts.
Tue Dec 1 20:57:02 2009 UTC (10 years ago) by olson
The scripts are calling these with "url => ''" which makes them not pick up the default URL.
Tue Nov 3 21:20:07 2009 UTC (10 years, 1 month ago) by parrello
Changes since 1.8: +7 -140 lines
Error handling restructure.
Tue Sep 8 21:31:32 2009 UTC (10 years, 3 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Changes since 1.7: +48 -29 lines
Changed to allow specification of 'localhost" for the server URL. When this is done, the SAP module is called directly instead of remotely through the server.
Wed Aug 5 19:45:46 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.6: +2 -5 lines
Moved SAS-component flag above copyright text.
Tue Aug 4 18:41:56 2009 UTC (10 years, 4 months ago) by parrello
Changed handling of documentation URL.
Mon Aug 3 21:31:42 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.4: +40 -7 lines
Updated to Sapling Server for Berkeley.
Wed Jul 15 23:37:46 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.3: +5 -1 lines
Updates for operon pipeline.
Tue Jun 30 20:11:54 2009 UTC (10 years, 5 months ago) by parrello
CVS Tags: rast_rel_2009_07_09
Additional functionality for sapling server.
Thu Jun 18 01:29:19 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.1: +7 -7 lines
Finished up the Sapling server methods.
Tue Jun 16 16:37:23 2009 UTC (10 years, 5 months ago) by parrello
New Sapling server support.
