[Bio] / FigKernelPackages / RemoteCustomAttributes.pm Repository:
Log of /FigKernelPackages/RemoteCustomAttributes.pm
Thu Dec 6 13:59:34 2007 UTC (12 years, 2 months ago) by parrello
Fri May 11 23:45:39 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.6: +41 -0 lines
Added support for new method to get information on the keys in a group.
Fri Apr 27 22:13:18 2007 UTC (12 years, 10 months ago) by parrello
Changes since 1.5: +43 -0 lines
Added support for the new QueryAttributes feature.
Thu Feb 22 21:29:58 2007 UTC (13 years ago) by parrello
Changes since 1.4: +34 -17 lines
Added support for DeleteMatchingAttributes.
Tue Jan 9 01:46:51 2007 UTC (13 years, 1 month ago) by parrello
Changes since 1.3: +38 -1 lines
Added support for the new attribute text search.
Thu Nov 16 22:09:09 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.2: +33 -0 lines
Added support for get-keys methods.
Wed Nov 15 11:50:47 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.1: +31 -0 lines
Added support for the EraseAttribute method.
Mon Nov 13 22:27:29 2006 UTC (13 years, 3 months ago) by parrello
Moved from Sprout library.
