[Bio] / FigKernelPackages / RASTserver.pm Repository:
Log of /FigKernelPackages/RASTserver.pm
Mon Aug 23 15:46:21 2010 UTC (9 years, 5 months ago) by olson
Changes since 1.20: +5 -1 lines
Diff to previous 1.20
cosmetic fix
Thu Jul 29 17:35:51 2010 UTC (9 years, 6 months ago) by parrello
Changes since 1.19: +3 -2 lines
Diff to previous 1.19
Added support for using SAS_SERVER environment variable to configure the appropriate server.
Thu Apr 1 20:25:29 2010 UTC (9 years, 10 months ago) by olson
CVS Tags: rast_rel_2010_0526
Changes since 1.18: +67 -7 lines
Diff to previous 1.18
Add chunked upload and directory support.
Tue Mar 30 21:50:10 2010 UTC (9 years, 10 months ago) by olson
Changes since 1.17: +24 -6 lines
Diff to previous 1.17
First working version of copy code
Tue Mar 30 20:40:51 2010 UTC (9 years, 10 months ago) by overbeek
Changes since 1.16: +61 -0 lines
Diff to previous 1.16
add copy command
Thu Dec 17 19:36:39 2009 UTC (10 years, 2 months ago) by disz
CVS Tags: rast_rel_2010_0118
Changes since 1.15: +1 -2 lines
Submit doc
Thu Dec 17 19:34:19 2009 UTC (10 years, 2 months ago) by disz
Changes since 1.14: +9 -6 lines
Added parms to submit job
Wed Dec 16 21:01:30 2009 UTC (10 years, 2 months ago) by disz
TYpo fixes
Wed Dec 16 20:01:02 2009 UTC (10 years, 2 months ago) by disz
Changes since 1.12: +152 -0 lines
Added pod doc
Fri Nov 20 17:38:20 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.11: +5 -0 lines
add get_job_metadata
Thu Oct 29 16:20:08 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.10: +10 -2 lines
Fix 666666 problem.
Add support for using the test server.
Wed Oct 28 20:40:26 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.9: +1 -0 lines
set error return
Wed Oct 28 20:38:38 2009 UTC (10 years, 3 months ago) by olson
fixups
Mon Oct 26 18:19:57 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.7: +0 -1 lines
Add SAS comments.
Add real implementation of user_may_access_job and user_owns_job in RAST_submission
so that the batch interface obeys the permissions set up by the RAST server.
Fri Oct 23 18:30:17 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.6: +26 -2 lines
Fix support for retreive_RAST_job so it sr
Thu Oct 22 21:15:13 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.5: +14 -0 lines
Lastest code. working submissions, plus kill & delete job.
Wed Oct 21 21:27:02 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.4: +11 -3 lines
add get_contigs_from_entrez
Wed Oct 21 20:18:47 2009 UTC (10 years, 4 months ago) by disz
Changes since 1.3: +58 -0 lines
Added parm checking for submit
Wed Oct 21 20:05:36 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.2: +7 -0 lines
Add support for get_contig_ids_in_project_from_entrez
Wed Oct 21 17:19:31 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.1: +7 -367 lines
added retrieve_RAST_job
Mon Oct 19 20:12:18 2009 UTC (10 years, 4 months ago) by olson
Rast submission server modules.
