[Bio] / FigKernelPackages / RAST_submission.pm Repository:
Log of /FigKernelPackages/RAST_submission.pm
Thu Jan 20 22:23:20 2011 UTC (9 years, 2 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_rel_2011_0119
Diff to previous 1.27 , to selected 1.2
typofix
Fri Dec 17 22:38:48 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.26: +2 -2 lines
Diff to previous 1.26 , to selected 1.2
Move to 7 6s
Mon Sep 20 20:53:45 2010 UTC (9 years, 6 months ago) by olson
CVS Tags: rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.25: +3 -1 lines
Diff to previous 1.25 , to selected 1.2
Support -determineFamily
Wed Aug 18 16:58:49 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: rast_rel_2010_0827
Changes since 1.24: +20 -8 lines
Diff to previous 1.24 , to selected 1.2
Update parser for new html format.
Fri Apr 2 19:02:19 2010 UTC (9 years, 11 months ago) by olson
CVS Tags: rast_rel_2010_0526
Changes since 1.23: +2 -1 lines
Diff to previous 1.23 , to selected 1.2
Allow anyone with access to the job to be able to upload data.
Unlink the spooled tarfile upon successful extraction.
Thu Apr 1 20:25:29 2010 UTC (9 years, 11 months ago) by olson
Changes since 1.22: +59 -8 lines
Diff to previous 1.22 , to selected 1.2
Add chunked upload and directory support.
Tue Mar 30 21:53:54 2010 UTC (10 years ago) by olson
Changes since 1.21: +1 -1 lines
Diff to previous 1.21 , to selected 1.2
bugfix
Tue Mar 30 21:50:10 2010 UTC (10 years ago) by olson
Changes since 1.20: +73 -0 lines
Diff to previous 1.20 , to selected 1.2
First working version of copy code
Tue Dec 22 22:15:17 2009 UTC (10 years, 3 months ago) by olson
CVS Tags: rast_rel_2010_0118
Diff to previous 1.19 , to selected 1.2
bugfix
Tue Dec 22 22:05:24 2009 UTC (10 years, 3 months ago) by olson
Diff to previous 1.18 , to selected 1.2
bugfix
Tue Dec 22 21:58:50 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.17: +2 -0 lines
Diff to previous 1.17 , to selected 1.2
add non-active support
Mon Dec 14 20:31:52 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.16: +4 -4 lines
Diff to previous 1.16 , to selected 1.2
don't check for resource missing, but look for ^LOCUS when downloading to catch different error cases.
Mon Dec 14 20:19:27 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.15: +50 -2 lines
Diff to previous 1.15 , to selected 1.2
NCBI will return documents containing "The resource is temporarily
unavailable" when a download times out. The transfer is not flagged as
an HTTP error, so the code was treating them as valid downloads.
This rev checks the content to make sure it does not contain that
message, and fails the download attempt if it does. It also checks the
content of the cache files in the event that there is bad cached data.
Fri Dec 4 18:24:36 2009 UTC (10 years, 3 months ago) by gdpusch
Changes since 1.14: +101 -18 lines
Diff to previous 1.14 , to selected 1.2
Added limited support for WGS accessions.
Mon Nov 23 20:38:04 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.13: +2 -3 lines
Diff to previous 1.13 , to selected 1.2
some minor fixups
Mon Nov 23 20:03:45 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.12: +56 -5 lines
Diff to previous 1.12 , to selected 1.2
Pull out the URL retrieval code into url_get() which will do a limited number of retries
when a specified set of error codes are returned.
Mon Nov 23 18:43:18 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.11: +95 -8 lines
Diff to previous 1.11 , to selected 1.2
Parse out the source lines, pull the dbxref from either the source that matches
the overall SOURCE for the genbank file, or from the first in the list if none matches exactly.
Fri Nov 20 17:38:06 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.10: +66 -1 lines
Diff to previous 1.10 , to selected 1.2
updates to rast submission module
Thu Oct 29 16:20:08 2009 UTC (10 years, 5 months ago) by olson
Fix 666666 problem.
Add support for using the test server.
Mon Oct 26 18:19:57 2009 UTC (10 years, 5 months ago) by olson
Changes since 1.8: +13 -4 lines
Add SAS comments.
Add real implementation of user_may_access_job and user_owns_job in RAST_submission
so that the batch interface obeys the permissions set up by the RAST server.
Fri Oct 23 18:30:17 2009 UTC (10 years, 5 months ago) by olson
Changes since 1.7: +13 -9 lines
Fix support for retreive_RAST_job so it sr
Thu Oct 22 21:15:13 2009 UTC (10 years, 5 months ago) by olson
Changes since 1.6: +383 -3 lines
Lastest code. working submissions, plus kill & delete job.
Wed Oct 21 21:45:03 2009 UTC (10 years, 5 months ago) by olson
Changes since 1.5: +28 -3 lines
Add more details to output of get_contigs_from_entrez:
$VAR1 = {
          'length' => '16660',
          'project' => '15760',
          'name' => 'Mycobacterium gilvum PYR-GCK',
          'contents' => '<genbank file>',
          'id' => 'NC_009341',
          'taxonomy_id' => '350054'
Wed Oct 21 21:27:02 2009 UTC (10 years, 5 months ago) by olson
Changes since 1.4: +28 -1 lines
add get_contigs_from_entrez
Wed Oct 21 20:05:36 2009 UTC (10 years, 5 months ago) by olson
Changes since 1.3: +224 -1 lines
Add support for get_contig_ids_in_project_from_entrez
Wed Oct 21 17:19:31 2009 UTC (10 years, 5 months ago) by olson
Changes since 1.2: +57 -0 lines
added retrieve_RAST_job
Tue Oct 20 20:43:30 2009 UTC (10 years, 5 months ago) by olson
Changes since 1.1: +69 -6 lines
fixes for the status checker
Mon Oct 19 20:12:18 2009 UTC (10 years, 5 months ago) by olson
Diff to selected 1.2
Rast submission server modules.
