[Bio] / FigKernelPackages / Quality.pm Repository:
Log of /FigKernelPackages/Quality.pm
Thu Dec 6 13:59:34 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.5: +30 -30 lines
Fri Dec 1 21:39:11 2006 UTC (13 years, 2 months ago) by olson
48hr fixes
Wed Nov 22 20:31:53 2006 UTC (13 years, 3 months ago) by overbeek
Changes since 1.3: +8 -7 lines
Modified the assessment wrappers to return the empty list on failure. -- /gdp
Wed Nov 22 20:22:02 2006 UTC (13 years, 3 months ago) by overbeek
Changes since 1.2: +18 -7 lines
Meta-fied assess_gene_call_quality; forced re-assessment after removes. -- /gdp
Wed Nov 8 23:14:00 2006 UTC (13 years, 3 months ago) by parrello
Fixed a POD error.
Fri Nov 3 18:02:32 2006 UTC (13 years, 3 months ago) by overbeek
Wrappers for genome and gene-call quality assessment and repair. -- /gdp
