[Bio] / FigKernelPackages / ProtSims.pm Repository:
Log of /FigKernelPackages/ProtSims.pm
Links to rast_rel_2011_0119: (view) (download) (as text) (annotate)
Revision 1.19 - (view) (download) (as text) (annotate) - [selected]
Tue Dec 28 20:09:07 2010 UTC (9 years, 3 months ago) by overbeek
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_rel_2011_0119
Diff to previous 1.18
turn off debugging print
Mon Oct 4 21:31:34 2010 UTC (9 years, 6 months ago) by olson
CVS Tags: rast_rel_2010_1206
Diff to previous 1.17 , to selected 1.19
Further uniquify temp files.
Mon Oct 4 21:15:28 2010 UTC (9 years, 6 months ago) by olson
Changes since 1.16: +16 -7 lines
Diff to previous 1.16 , to selected 1.19
Name temp files with more than just the process id.
Tue Sep 14 21:34:35 2010 UTC (9 years, 6 months ago) by olson
CVS Tags: rast_rel_2010_0928
Changes since 1.15: +36 -2 lines
Diff to previous 1.15 , to selected 1.19
Fixes for running under FCGI; also run with -a 4 if we're under FCGI and we can tell that
the system load is low enough.
Tue Sep 14 19:09:17 2010 UTC (9 years, 6 months ago) by olson
Changes since 1.14: +28 -4 lines
Diff to previous 1.14 , to selected 1.19
use nr lengths btree if computed
Mon Aug 30 16:21:34 2010 UTC (9 years, 7 months ago) by olson
Changes since 1.13: +27 -6 lines
Diff to previous 1.13 , to selected 1.19
Convert to not use -| as that is not available on windows perl
Mon Aug 30 16:09:00 2010 UTC (9 years, 7 months ago) by olson
Changes since 1.12: +47 -29 lines
Diff to previous 1.12 , to selected 1.19
Convert to use SeedAware.pm, remove unnecessary cat / shell usage.
Sat Mar 6 23:54:11 2010 UTC (10 years, 1 month ago) by overbeek
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827
Diff to previous 1.11 , to selected 1.19
allow use of just blast
Wed Feb 17 19:34:10 2010 UTC (10 years, 1 month ago) by parrello
Changes since 1.10: +5 -3 lines
Diff to previous 1.10 , to selected 1.19
Changed to work better if FIG_Config is present but no external bin directory is defined.
Thu Dec 17 21:35:24 2009 UTC (10 years, 3 months ago) by olson
CVS Tags: rast_rel_2010_0118
Changes since 1.9: +19 -5 lines
Diff to previous 1.9 , to selected 1.19
Distro fixups
Sat Dec 12 23:43:13 2009 UTC (10 years, 3 months ago) by overbeek
Diff to previous 1.8 , to selected 1.19
fix sort
Sat Nov 7 18:37:44 2009 UTC (10 years, 4 months ago) by overbeek
Diff to previous 1.7 , to selected 1.19
unlink generated formatdb file
Sun Aug 23 17:23:53 2009 UTC (10 years, 7 months ago) by overbeek
CVS Tags: rast_rel_2009_0925
Changes since 1.6: +14 -6 lines
Diff to previous 1.6 , to selected 1.19
condensing sets of hits against a sequence
Sun Aug 23 01:37:28 2009 UTC (10 years, 7 months ago) by overbeek
Diff to previous 1.5 , to selected 1.19
condense multiple sims from same pair
Sun Aug 23 01:20:23 2009 UTC (10 years, 7 months ago) by overbeek
Changes since 1.4: +33 -2 lines
Diff to previous 1.4 , to selected 1.19
Fri Aug 21 21:31:01 2009 UTC (10 years, 7 months ago) by olson
Changes since 1.3: +18 -12 lines
Diff to previous 1.3 , to selected 1.19
some bugfixes
Wed Aug 19 16:12:10 2009 UTC (10 years, 7 months ago) by overbeek
Diff to previous 1.2 , to selected 1.19
fix passing tuples
Tue Aug 18 15:16:21 2009 UTC (10 years, 7 months ago) by overbeek
Changes since 1.1: +4 -2 lines
Diff to previous 1.1 , to selected 1.19
minor fixes
Tue Aug 18 15:11:51 2009 UTC (10 years, 7 months ago) by overbeek
Diff to selected 1.19
Blat then blast
