[Bio] / FigKernelPackages / ProtSims.pm Repository:
Log of /FigKernelPackages/ProtSims.pm
Mon Oct 4 21:31:34 2010 UTC (9 years, 2 months ago) by olson
CVS Tags: rast_rel_2010_1206
Diff to previous 1.17 , to selected 1.12
Further uniquify temp files.
Mon Oct 4 21:15:28 2010 UTC (9 years, 2 months ago) by olson
Changes since 1.16: +16 -7 lines
Diff to previous 1.16 , to selected 1.12
Name temp files with more than just the process id.
Tue Sep 14 21:34:35 2010 UTC (9 years, 3 months ago) by olson
CVS Tags: rast_rel_2010_0928
Changes since 1.15: +36 -2 lines
Diff to previous 1.15 , to selected 1.12
Fixes for running under FCGI; also run with -a 4 if we're under FCGI and we can tell that
the system load is low enough.
Tue Sep 14 19:09:17 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.14: +28 -4 lines
Diff to previous 1.14 , to selected 1.12
use nr lengths btree if computed
Mon Aug 30 16:21:34 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.13: +27 -6 lines
Diff to previous 1.13 , to selected 1.12
Convert to not use -| as that is not available on windows perl
Mon Aug 30 16:09:00 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.12: +47 -29 lines
Convert to use SeedAware.pm, remove unnecessary cat / shell usage.
Revision 1.12 - (view) (download) (as text) (annotate) - [selected]
Sat Mar 6 23:54:11 2010 UTC (9 years, 9 months ago) by overbeek
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827
allow use of just blast
Wed Feb 17 19:34:10 2010 UTC (9 years, 9 months ago) by parrello
Changes since 1.10: +5 -3 lines
Diff to previous 1.10 , to selected 1.12
Changed to work better if FIG_Config is present but no external bin directory is defined.
Thu Dec 17 21:35:24 2009 UTC (9 years, 11 months ago) by olson
CVS Tags: rast_rel_2010_0118
Changes since 1.9: +19 -5 lines
Diff to previous 1.9 , to selected 1.12
Distro fixups
Sat Dec 12 23:43:13 2009 UTC (10 years ago) by overbeek
Diff to previous 1.8 , to selected 1.12
fix sort
Sat Nov 7 18:37:44 2009 UTC (10 years, 1 month ago) by overbeek
Diff to previous 1.7 , to selected 1.12
unlink generated formatdb file
Sun Aug 23 17:23:53 2009 UTC (10 years, 3 months ago) by overbeek
CVS Tags: rast_rel_2009_0925
Changes since 1.6: +14 -6 lines
Diff to previous 1.6 , to selected 1.12
condensing sets of hits against a sequence
Sun Aug 23 01:37:28 2009 UTC (10 years, 3 months ago) by overbeek
Diff to previous 1.5 , to selected 1.12
condense multiple sims from same pair
Sun Aug 23 01:20:23 2009 UTC (10 years, 3 months ago) by overbeek
Changes since 1.4: +33 -2 lines
Diff to previous 1.4 , to selected 1.12
Fri Aug 21 21:31:01 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.3: +18 -12 lines
Diff to previous 1.3 , to selected 1.12
some bugfixes
Wed Aug 19 16:12:10 2009 UTC (10 years, 3 months ago) by overbeek
Diff to previous 1.2 , to selected 1.12
fix passing tuples
Tue Aug 18 15:16:21 2009 UTC (10 years, 3 months ago) by overbeek
Changes since 1.1: +4 -2 lines
Diff to previous 1.1 , to selected 1.12
minor fixes
Tue Aug 18 15:11:51 2009 UTC (10 years, 3 months ago) by overbeek
Diff to selected 1.12
Blat then blast
