[Bio] / FigKernelPackages / ProtSims.pm Repository:
Log of /FigKernelPackages/ProtSims.pm
Revision 1.12 - (view) (download) (as text) (annotate) - [selected]
Sat Mar 6 23:54:11 2010 UTC (9 years, 10 months ago) by overbeek
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827
allow use of just blast
Wed Feb 17 19:34:10 2010 UTC (9 years, 11 months ago) by parrello
Changes since 1.10: +5 -3 lines
Diff to previous 1.10 , to selected 1.12
Changed to work better if FIG_Config is present but no external bin directory is defined.
Thu Dec 17 21:35:24 2009 UTC (10 years, 1 month ago) by olson
CVS Tags: rast_rel_2010_0118
Changes since 1.9: +19 -5 lines
Diff to previous 1.9 , to selected 1.12
Distro fixups
Sat Dec 12 23:43:13 2009 UTC (10 years, 1 month ago) by overbeek
Diff to previous 1.8 , to selected 1.12
fix sort
Sat Nov 7 18:37:44 2009 UTC (10 years, 2 months ago) by overbeek
Diff to previous 1.7 , to selected 1.12
unlink generated formatdb file
Sun Aug 23 17:23:53 2009 UTC (10 years, 4 months ago) by overbeek
CVS Tags: rast_rel_2009_0925
Changes since 1.6: +14 -6 lines
Diff to previous 1.6 , to selected 1.12
condensing sets of hits against a sequence
Sun Aug 23 01:37:28 2009 UTC (10 years, 4 months ago) by overbeek
Diff to previous 1.5 , to selected 1.12
condense multiple sims from same pair
Sun Aug 23 01:20:23 2009 UTC (10 years, 4 months ago) by overbeek
Changes since 1.4: +33 -2 lines
Diff to previous 1.4 , to selected 1.12
Fri Aug 21 21:31:01 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.3: +18 -12 lines
Diff to previous 1.3 , to selected 1.12
some bugfixes
Wed Aug 19 16:12:10 2009 UTC (10 years, 5 months ago) by overbeek
Diff to previous 1.2 , to selected 1.12
fix passing tuples
Tue Aug 18 15:16:21 2009 UTC (10 years, 5 months ago) by overbeek
Changes since 1.1: +4 -2 lines
Diff to previous 1.1 , to selected 1.12
minor fixes
Tue Aug 18 15:11:51 2009 UTC (10 years, 5 months ago) by overbeek
Diff to selected 1.12
Blat then blast
