[Bio] / FigKernelPackages / PropagateGBMetadata.pm Repository:
Log of /FigKernelPackages/PropagateGBMetadata.pm
Mon Feb 29 17:37:45 2016 UTC (4 years, 1 month ago) by olson
CVS Tags: HEAD
Changes since 1.2: +8 -1 lines
Adjust interval tree endpoint.
Wed Nov 18 22:20:02 2015 UTC (4 years, 4 months ago) by olson
add sas
Thu Oct 15 19:23:39 2015 UTC (4 years, 5 months ago) by olson
Propagate genbank metadata from features imported from genbank file to the appropriate matching features.
