[Bio] / FigKernelPackages / PinnedRegions.pm Repository:
Log of /FigKernelPackages/PinnedRegions.pm
Fri May 16 19:26:54 2008 UTC (11 years, 9 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.11: +3 -2 lines
Fixed a compiler warning.
Tue Apr 29 05:45:29 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.10: +452 -447 lines
Added some trace messages.
Thu Apr 17 20:45:23 2008 UTC (11 years, 10 months ago) by olson
CVS Tags: rast_rel_2008_04_23
Introduce get_figfam_data().
Sun Mar 23 15:54:41 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.8: +4 -6 lines
Added tracing.
Tue Feb 26 17:44:16 2008 UTC (11 years, 11 months ago) by bartels
Changes since 1.7: +58 -2 lines
added add_features for features you do not get from the seed.
Wed Feb 20 19:23:58 2008 UTC (11 years, 11 months ago) by dsouza
Changes since 1.6: +15 -1 lines
PEG popup changed so that FigFam ID does not get repeated (was twice) for
FigFams which are not based on subsystems. This can be removed if the
FigFam function format gets changed.
Wed Feb 6 18:30:07 2008 UTC (12 years ago) by dsouza
Changes since 1.5: +19 -10 lines
Bug fix for user selected genomes.
Tue Feb 5 21:04:36 2008 UTC (12 years ago) by dsouza
Changes since 1.4: +51 -7 lines
1. Added FigFam name to feature data (for PEGs in FigFams).
2. Added support for user selection of region genomes.
Mon Jan 14 16:38:27 2008 UTC (12 years, 1 month ago) by dsouza
Changes since 1.3: +7 -8 lines
Comments and whitespace changes
Fri Dec 21 17:22:47 2007 UTC (12 years, 1 month ago) by dsouza
Changes since 1.2: +127 -117 lines
Added protein length, subsystem information, functional coupling.
Changed behavior of 'collapse close genomes'.
Thu Dec 13 23:16:03 2007 UTC (12 years, 2 months ago) by dsouza
Changes since 1.1: +28 -26 lines
Modified selection of PEGs for non-collapsed regions.
Fri Nov 30 17:22:16 2007 UTC (12 years, 2 months ago) by dsouza
PinnedRegions.pm creates the data structure used to create the
'compared regions' images.
It creates the list of pinned PEGs (based on similarity or PCH pins), gets
all the feature data for their contig regions required to create the image,
and packages it in a single data structure.
Mark D'Souza, 2007-11-30
