[Bio] / FigKernelPackages / PinnedRegions.pm Repository:
Log of /FigKernelPackages/PinnedRegions.pm
Wed Sep 29 15:48:37 2010 UTC (9 years, 1 month ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119
Diff to previous 1.33
fix unlink here too
Mon Sep 27 16:09:28 2010 UTC (9 years, 1 month ago) by olson
CVS Tags: rast_rel_2010_0928
Changes since 1.32: +22 -0 lines
Diff to previous 1.32
Clean up tmp files.
Wed Jun 16 21:55:31 2010 UTC (9 years, 5 months ago) by olson
CVS Tags: rast_rel_2010_0827
Changes since 1.31: +37 -36 lines
Diff to previous 1.31
make this run with new FFs
Fri Apr 23 20:24:22 2010 UTC (9 years, 6 months ago) by olson
CVS Tags: rast_rel_2010_0526
Changes since 1.30: +25 -5 lines
Diff to previous 1.30
use bulk lookups
Fri Apr 2 09:42:27 2010 UTC (9 years, 7 months ago) by paczian
Changes since 1.29: +11 -5 lines
Diff to previous 1.29
added support for Sapling type locations
Tue Mar 16 16:01:54 2010 UTC (9 years, 8 months ago) by paczian
Changes since 1.28: +7 -2 lines
Diff to previous 1.28
added support for locations
Wed Sep 16 09:34:32 2009 UTC (10 years, 2 months ago) by paczian
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118
Diff to previous 1.27
added location for artificial features
Wed Sep 2 09:38:10 2009 UTC (10 years, 2 months ago) by paczian
Changes since 1.26: +5 -1 lines
Diff to previous 1.26
fixed size information
Wed Sep 2 09:28:24 2009 UTC (10 years, 2 months ago) by paczian
Changes since 1.25: +1 -0 lines
Diff to previous 1.25
added location to feature data
Mon Aug 17 21:19:54 2009 UTC (10 years, 3 months ago) by dsouza
Changes since 1.24: +138 -113 lines
Diff to previous 1.24
Removed code using blat.
Thu Aug 13 20:34:15 2009 UTC (10 years, 3 months ago) by dsouza
Changes since 1.23: +116 -173 lines
Diff to previous 1.23
Fixed blat code, removed fast color option.
Wed Aug 12 17:32:45 2009 UTC (10 years, 3 months ago) by overbeek
Changes since 1.22: +4 -1 lines
Diff to previous 1.22
use blat
Wed Aug 12 17:14:14 2009 UTC (10 years, 3 months ago) by dsouza
Changes since 1.21: +34 -5 lines
Diff to previous 1.21
Changed to use blat when present, otherwise use blast
Wed Jun 24 19:52:31 2009 UTC (10 years, 4 months ago) by dsouza
CVS Tags: rast_rel_2009_07_09
Changes since 1.20: +50 -7 lines
Diff to previous 1.20
Added sort display order of regions by similarity of pin to input peg
Thu Jun 4 12:30:37 2009 UTC (10 years, 5 months ago) by paczian
Changes since 1.19: +11 -4 lines
Diff to previous 1.19
subsystems with comments due to their variant code will now receive the correct index
Wed Mar 25 18:00:13 2009 UTC (10 years, 7 months ago) by paczian
Changes since 1.18: +5 -1 lines
Diff to previous 1.18
fixed display of subsystems
Mon Mar 9 17:01:25 2009 UTC (10 years, 8 months ago) by paczian
Changes since 1.17: +1 -0 lines
Diff to previous 1.17
corrected subsystem visibility
Thu Feb 12 13:50:32 2009 UTC (10 years, 9 months ago) by paczian
Changes since 1.16: +5 -3 lines
Diff to previous 1.16
the extended option now causes skipping of the usable_subsystem test
Thu Feb 5 15:43:22 2009 UTC (10 years, 9 months ago) by paczian
Changes since 1.15: +66 -44 lines
added optional extended information (aliases and ev codes)
optimized data retrieval
Thu Nov 6 11:07:34 2008 UTC (11 years ago) by paczian
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05
Changes since 1.14: +3 -0 lines
added functional coupling pin
Wed Oct 22 18:18:31 2008 UTC (11 years, 1 month ago) by dsouza
Changes since 1.13: +43 -20 lines
Changed to handle subsystem variant codes correctly.
Sat Oct 18 09:56:23 2008 UTC (11 years, 1 month ago) by parrello
Changes since 1.12: +4 -3 lines
Added tracing.
Fri May 16 19:26:54 2008 UTC (11 years, 6 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.11: +3 -2 lines
Fixed a compiler warning.
Tue Apr 29 05:45:29 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.10: +452 -447 lines
Added some trace messages.
Thu Apr 17 20:45:23 2008 UTC (11 years, 7 months ago) by olson
CVS Tags: rast_rel_2008_04_23
Introduce get_figfam_data().
Sun Mar 23 15:54:41 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.8: +4 -6 lines
Added tracing.
Tue Feb 26 17:44:16 2008 UTC (11 years, 8 months ago) by bartels
Changes since 1.7: +58 -2 lines
added add_features for features you do not get from the seed.
Wed Feb 20 19:23:58 2008 UTC (11 years, 9 months ago) by dsouza
Changes since 1.6: +15 -1 lines
PEG popup changed so that FigFam ID does not get repeated (was twice) for
FigFams which are not based on subsystems. This can be removed if the
FigFam function format gets changed.
Wed Feb 6 18:30:07 2008 UTC (11 years, 9 months ago) by dsouza
Changes since 1.5: +19 -10 lines
Bug fix for user selected genomes.
Tue Feb 5 21:04:36 2008 UTC (11 years, 9 months ago) by dsouza
Changes since 1.4: +51 -7 lines
1. Added FigFam name to feature data (for PEGs in FigFams).
2. Added support for user selection of region genomes.
Mon Jan 14 16:38:27 2008 UTC (11 years, 10 months ago) by dsouza
Changes since 1.3: +7 -8 lines
Comments and whitespace changes
Fri Dec 21 17:22:47 2007 UTC (11 years, 11 months ago) by dsouza
Changes since 1.2: +127 -117 lines
Added protein length, subsystem information, functional coupling.
Changed behavior of 'collapse close genomes'.
Thu Dec 13 23:16:03 2007 UTC (11 years, 11 months ago) by dsouza
Changes since 1.1: +28 -26 lines
Modified selection of PEGs for non-collapsed regions.
Fri Nov 30 17:22:16 2007 UTC (11 years, 11 months ago) by dsouza
PinnedRegions.pm creates the data structure used to create the
'compared regions' images.
It creates the list of pinned PEGs (based on similarity or PCH pins), gets
all the feature data for their contig regions required to create the image,
and packages it in a single data structure.
Mark D'Souza, 2007-11-30
