[Bio] / FigKernelPackages / PersistentSets.pm Repository:
View of /FigKernelPackages/PersistentSets.pm
Revision 1.3 - (download) (as text) (annotate)
Fri Sep 16 20:17:32 2011 UTC (8 years, 6 months ago) by disz
CVS Tags: rast_rel_2014_0912, rast_rel_2014_0729, mgrast_release_3_1_2, rast_rel_2011_0928, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_10262011, HEAD
Changes since 1.2: +28 -4 lines
filled in all functions
# Public License.
package PersistentSets;;
use FIG;
use FileHandle;
use strict;
use Data::Dumper;
my $fig = new FIG;
my $dbh = $fig->seed_global_dbh();
1;
sub new {
  my ( $class, $self ) = @_;
  bless( $self, $class );
  return $self;
sub create_set {
  my ($type, $name, $owner, $desc, $validate ) = @_;
  my $cmd = "INSERT INTO feature_set (set_name, owner, set_type, description) VALUES('$name', '$owner', '$type', '$desc')";
  my $response;
  eval {
  	$response = $dbh->SQL($cmd);
  if ($@ =~ /Duplicate/i) {
	return;
  } else {
	return $name;
sub enumerate_sets_by_owner
    my($owner) = @_;
    my $cmd = "SELECT set_name from feature_set where owner = \'$owner\'";
    my $res = $dbh->SQL($cmd);
    my @sets;
    for my $set (@$res) {
	push (@sets, $set->[0]);
    return \@sets;
sub type_of_set
    my($name, $owner) = @_;
    my $cmd = "SELECT set_type FROM feature_set where set_name = \'$name\' and owner = \'$owner\'";
    return (@$res == 1) ? $res->[0]->[0] : undef;
    # Return type, or undef if doesn't exist
sub put_to_set {
	my ($name, $owner, $items, $validate) = @_;
        my $res;
	foreach my $id (@$items) {
		my $cmd = "INSERT INTO feature_set_entry (set_name, owner, feature_id) VALUES('$name', '$owner', '$id')";
		eval {
		if ($@ =~ /foreign key constraint fails/) {
			return;
	return 1;
sub delete_from_set {
        my $res;
		my $cmd = "DELETE FROM feature_set_entry WHERE set_name = \'$name\' and owner = \'$owner\' and feature_id = \'$id\'";
		eval {
			return;
	return 1;
sub get_set {
	my ($name, $owner) = @_;
	my $res = $dbh->SQL("SELECT feature_id FROM feature_set_entry WHERE set_name = \'$name\' and owner = \'$owner\'");
        my @fids;
	for my $id (@$res) {
		push (@fids, $id->[0]);
	return \@fids;
sub delete_set {
        my $ret = "";
	eval {
		my $res = $dbh->SQL("DELETE from feature_set_entry WHERE set_name = \'$name\' and owner = \'$owner\'");
	my $res = $dbh->SQL("DELETE from feature_set WHERE set_name = \'$name\' and owner = \'$owner\'");
	return $ret;
