[Bio] / FigKernelPackages / PageBuilder.pm Repository:
Log of /FigKernelPackages/PageBuilder.pm
Thu Dec 6 13:59:34 2007 UTC (11 years, 11 months ago) by parrello
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_release_2008_09_29
Changes since 1.13: +14 -14 lines
Tue Apr 10 03:49:48 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.12: +5 -2 lines
Fixed some trace messages.
Wed Nov 8 23:13:12 2006 UTC (13 years ago) by parrello
Changes since 1.11: +56 -0 lines
Added a method to make the standard NMPDR odd-even table.
Mon Oct 16 22:47:40 2006 UTC (13 years ago) by parrello
Changes since 1.10: +1 -0 lines
Added tracing for template variables.
Fri Sep 29 14:58:32 2006 UTC (13 years, 1 month ago) by parrello
Changes since 1.9: +41 -8 lines
Added a new method for retrieving a web page from a server.
Fri Jul 28 02:01:08 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.8: +45 -44 lines
Converted to use PERL template system.
Thu Jul 20 05:29:05 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.7: +2 -0 lines
Added tracing.
Thu Jul 20 05:09:12 2006 UTC (13 years, 3 months ago) by parrello
Fixed a bug in a Confess call.
Sun Jul 16 17:28:54 2006 UTC (13 years, 4 months ago) by parrello
Undid a stupid mistake.
Wed Jul 12 21:06:03 2006 UTC (13 years, 4 months ago) by parrello
Upgraded a trace message.
Wed Jul 12 02:41:32 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.3: +131 -121 lines
Added the ability to specify a URL for a template page.
Mon Dec 5 19:06:30 2005 UTC (13 years, 11 months ago) by olson
Added license words.
Thu Jun 23 21:24:48 2005 UTC (14 years, 4 months ago) by overbeek
CVS Tags: caBIG-00-00-00, caBIG-dataload-0, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
finally
Wed May 4 03:01:52 2005 UTC (14 years, 6 months ago) by parrello
CVS Tags: Root-bobdev_news
