[Bio] / FigKernelPackages / P3WorkspaceClient.pm Repository:
Log of /FigKernelPackages/P3WorkspaceClient.pm
Thu Jun 29 17:30:47 2017 UTC (2 years, 11 months ago) by parrello
CVS Tags: HEAD
Changes since 1.5: +5 -7 lines
Changes copied from SEEDtk project.
Tue Dec 13 22:45:34 2016 UTC (3 years, 5 months ago) by olson
Changes since 1.4: +6 -0 lines
Add token-via-p3dataapi support (for windows)
Fri Nov 11 20:14:19 2016 UTC (3 years, 6 months ago) by olson
Put the SAS header back.
Tue Nov 8 17:33:46 2016 UTC (3 years, 6 months ago) by parrello
Changes since 1.2: +605 -603 lines
Thu Sep 22 20:04:48 2016 UTC (3 years, 8 months ago) by olson
add sas header
Wed Sep 14 20:46:27 2016 UTC (3 years, 8 months ago) by olson
Add P3 genome/feature group support.
