[Bio] / FigKernelPackages / P2Pupdate.pm Repository:
Log of /FigKernelPackages/P2Pupdate.pm
Links to mgrast_dev_05262011: (view) (download) (as text) (annotate)
Sat Aug 23 23:39:22 2008 UTC (11 years, 7 months ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_release_2008_09_29
Changes since 1.61: +26 -20 lines
Diff to previous 1.61
Move writing of assignment annotation from a case-by-case basis (and it
was missing in several key places) to the FIG::assign_function.
Modify the code in each of the calling locations to not make duplicate
annotations.
At the same time, remove (most) of the instances of making different
calls to assign_function depending on the user name.  assign_function
treats everyone as master (but writes an annotation with the real user
name).
Tue Feb 5 02:02:29 2008 UTC (12 years, 2 months ago) by parrello
CVS Tags: rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07
Changes since 1.60: +19 -17 lines
Diff to previous 1.60
Changed POD heading levels.
Wed Aug 8 21:55:29 2007 UTC (12 years, 8 months ago) by olson
Changes since 1.59: +1 -1 lines
Diff to previous 1.59
Fix diagram update bug on isntall of existing subystem.
Tue Mar 13 16:45:29 2007 UTC (13 years ago) by olson
Changes since 1.58: +20 -1 lines
Diff to previous 1.58
non-peg ss install fix
Mon Jan 22 22:44:31 2007 UTC (13 years, 2 months ago) by olson
Changes since 1.57: +7 -2 lines
Diff to previous 1.57
other part of this
Fri Jan 13 20:22:39 2006 UTC (14 years, 2 months ago) by overbeek
Changes since 1.56: +12 -6 lines
Diff to previous 1.56
fixes to deleted_features, replace_features_with, etc
Mon Dec 5 19:06:30 2005 UTC (14 years, 4 months ago) by olson
Changes since 1.55: +17 -0 lines
Diff to previous 1.55
Added license words.
Tue Sep 6 18:52:35 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.54: +2 -5 lines
Diff to previous 1.54
Make annotations_made_fast return new Annotation objects instead of arrays of data.
Add the Annotation object.
Thu Sep 1 19:23:49 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.53: +3 -0 lines
Diff to previous 1.53
Add FIG::by_genome_id for sorting genome ID lists.
Add $fig->extract_assignments_from_annoatations to transform the output of annotations_made_fast
to a list of the current assignments (per the annotations data).
Thu Sep 1 18:23:49 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.52: +23 -28 lines
Diff to previous 1.52
Add fast= flag to package_annotations, and the %options array in P2Pupdate::pacakge_annotations
to support it. (skip_aliases and skip_sequences support). Makes export of annotations to a
SEED that you know has the same data for the same ID *MUCH* faster.
Thu Sep 1 18:14:53 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.51: +77 -0 lines
Diff to previous 1.51
make package_annotations use $fig->annotations_made_fast.
Add date parsing to FIG.pm ($fig->parse_date) using Date::Parse if available.
Mon Aug 8 21:54:39 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.50: +5 -5 lines
Diff to previous 1.50
More diagram changes.
Add new simple start page.
Wed Aug 3 17:40:42 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.49: +184 -9 lines
Diff to previous 1.49
Add support for creating and parsing diagram data as part of subsystem clearinghouse packages.
Fri Jul 29 22:39:49 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.48: +28 -0 lines
Diff to previous 1.48
Reactions support for subsystem downloads.
Fri Jun 17 18:41:48 2005 UTC (14 years, 9 months ago) by olson
Changes since 1.47: +2 -2 lines
Diff to previous 1.47
Fix number  of spaces in annotation.
Fri Apr 29 17:03:32 2005 UTC (14 years, 11 months ago) by olson
CVS Tags: Root-bobdev_news
Changes since 1.46: +59 -1 lines
Diff to previous 1.46
Add install-anno-from gff routine (first cut).
Fix mismatched brace.
Tue Apr 26 15:08:26 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.45: +7 -0 lines
Diff to previous 1.45
document importing external protein sequences
Tue Apr 19 03:01:45 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.44: +5 -1 lines
Diff to previous 1.44
various fixes to package/install annotations
Mon Apr 18 17:45:40 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.43: +4 -2 lines
Diff to previous 1.43
fix evil bug in install_assignments
Sun Apr 17 15:29:47 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.42: +1 -1 lines
Diff to previous 1.42
Fix bad bug in install annotations
Fri Jan 7 18:53:40 2005 UTC (15 years, 3 months ago) by olson
Changes since 1.41: +11 -1 lines
Diff to previous 1.41
support skipping assignments in p2p subsystem install
Fri Dec 17 23:20:56 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.40: +41 -4 lines
Diff to previous 1.40
More subsystem/p2p fixes.
Fri Dec 17 21:33:11 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.39: +45 -3 lines
Diff to previous 1.39
Some changes for subsystem import analysis.
Mon Dec 6 18:26:56 2004 UTC (15 years, 4 months ago) by olson
Changes since 1.38: +503 -42 lines
Diff to previous 1.38
Add subsystem install stuff.
Fri Sep 17 15:39:59 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.37: +0 -1 lines
Diff to previous 1.37
Fix parsing bug.
Thu Sep 16 15:15:57 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.36: +135 -3 lines
Diff to previous 1.36
remove inappropriate setting of g+s bit
Mon Aug 9 14:38:55 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.35: +9 -4 lines
Diff to previous 1.35
export only current assignments (not all that were made)
Sun Jul 25 21:48:15 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.34: +36 -7 lines
Diff to previous 1.34
sort links
Tue Jun 29 14:15:57 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.33: +11 -11 lines
Diff to previous 1.33
Fix
Mon Jun 28 20:10:11 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.32: +400 -11 lines
Diff to previous 1.32
Fixes needed to run with 'use strict'.
Add analysis code for new subsystem import.
Wed Jun 16 14:13:35 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.31: +6 -0 lines
Diff to previous 1.31
Put ext-bin in the path for swithc_to_release.
Thu Apr 1 22:07:31 2004 UTC (16 years ago) by disz
Changes since 1.30: +6 -6 lines
Diff to previous 1.30
More P2P fixes.
Add setgid to the mkdir/chmod's.
Wed Mar 31 18:39:15 2004 UTC (16 years ago) by overbeek
Changes since 1.29: +14 -10 lines
Diff to previous 1.29
p2p changes
Wed Mar 31 16:32:22 2004 UTC (16 years ago) by overbeek
Changes since 1.28: +136 -37 lines
Diff to previous 1.28
attempt to fix package/install for p2p
Wed Mar 31 11:14:47 2004 UTC (16 years ago) by overbeek
Changes since 1.27: +8 -0 lines
Diff to previous 1.27
move PEG translation into FIG.pm
Wed Mar 31 10:52:25 2004 UTC (16 years ago) by overbeek
Changes since 1.26: +18 -5 lines
Diff to previous 1.26
updates relating to p2p and installing new releases
Tue Mar 30 16:44:51 2004 UTC (16 years ago) by olson
Diff to previous 1.25
fix cmdline argument to install_annotations
Wed Mar 24 00:05:40 2004 UTC (16 years ago) by overbeek
Changes since 1.24: +6 -1 lines
Diff to previous 1.24
export subsystems stuff
Tue Mar 23 23:50:58 2004 UTC (16 years ago) by overbeek
Changes since 1.23: +4 -4 lines
Diff to previous 1.23
fix exportable -> exchangable
Wed Mar 17 18:17:34 2004 UTC (16 years ago) by overbeek
Changes since 1.22: +17 -0 lines
Diff to previous 1.22
basic export of subsystems stuff
Tue Feb 10 22:33:42 2004 UTC (16 years, 2 months ago) by olson
Changes since 1.21: +24 -0 lines
Diff to previous 1.21
we need to find the architecture for this seed; since configure doesn't
save it, we go grunking in the generated config/fig-user-env.sh script.
Wed Jan 21 20:23:55 2004 UTC (16 years, 2 months ago) by overbeek
Diff to previous 1.20
fix format
Wed Jan 21 18:27:29 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.19: +28 -200 lines
Diff to previous 1.19
from the Penn trip
Wed Jan 7 03:34:13 2004 UTC (16 years, 3 months ago) by overbeek
Diff to previous 1.18
make Assignments files have readable names
Wed Jan 7 03:12:44 2004 UTC (16 years, 3 months ago) by overbeek
Changes since 1.17: +6 -7 lines
Diff to previous 1.17
make p2p assignments get written to Assignments
Sat Jan 3 14:13:48 2004 UTC (16 years, 3 months ago) by overbeek
Changes since 1.16: +16 -55 lines
Diff to previous 1.16
fix P2P to use get_assignments
Sat Jan 3 06:03:43 2004 UTC (16 years, 3 months ago) by overbeek
changes to annotations to allow extraction of assignments
Tue Dec 23 22:17:56 2003 UTC (16 years, 3 months ago) by efrank
handle null length annotation exchanges
Tue Dec 23 21:29:02 2003 UTC (16 years, 3 months ago) by efrank
fix quote
Tue Dec 23 21:10:26 2003 UTC (16 years, 3 months ago) by efrank
Changes since 1.12: +4 -0 lines
reject genomes that we do not have here on p2p updates
Tue Dec 23 20:21:31 2003 UTC (16 years, 3 months ago) by efrank
add who from on install_annotations
Tue Dec 23 19:48:53 2003 UTC (16 years, 3 months ago) by efrank
Changes since 1.10: +1 -0 lines
File Permissions
Tue Dec 23 17:38:35 2003 UTC (16 years, 3 months ago) by efrank
Changes since 1.9: +3 -4 lines
fixes to p2p
Mon Dec 22 21:34:15 2003 UTC (16 years, 3 months ago) by efrank
Changes since 1.8: +5 -5 lines
Added full path for commands like "merge_annotations"
Mon Dec 22 08:59:04 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.7: +13 -4 lines
added logging for p2p assignment exchanges
Mon Dec 22 08:42:00 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.6: +15 -24 lines
fixes to package_assignments
Mon Dec 22 03:37:42 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.5: +10 -2 lines
corrections to package assignments
Mon Dec 22 02:56:46 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.4: +32 -9 lines
Sat Dec 20 15:19:21 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.3: +21 -17 lines
for incremental additions to the DB, delete old versions of things
Fri Dec 19 20:04:52 2003 UTC (16 years, 3 months ago) by efrank
P2P Stuff
Fri Dec 19 17:19:58 2003 UTC (16 years, 3 months ago) by overbeek
Changes since 1.1: +39 -21 lines
fixes to p2p updates
Mon Dec 1 16:54:26 2003 UTC (16 years, 4 months ago) by efrank
Branch point for: initial
