[Bio] / FigKernelPackages / P2P.pm Repository:
Log of /FigKernelPackages/P2P.pm
Links to mgrast_dev_03312011: (view) (download) (as text) (annotate)
Changes since 1.30: +17 -0 lines
Diff to previous 1.30
Added license words.
Wed May 4 21:42:50 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.29: +2 -1 lines
Diff to previous 1.29
Wed Feb 23 22:07:14 2005 UTC (14 years, 10 months ago) by olson
Diff to previous 1.28
Fix p2p annotations file problem.
Thu Feb 10 16:55:46 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.27: +2 -1 lines
Diff to previous 1.27
Fix a comment.
Tue Jan 11 20:15:59 2005 UTC (15 years ago) by olson
Changes since 1.26: +66 -13 lines
Diff to previous 1.26
Fix code for multiple matches in contig match.
Add support for passing credentials via P2P::Requestor constructor.
Tue Jan 11 14:06:18 2005 UTC (15 years ago) by olson
Changes since 1.25: +13 -6 lines
Diff to previous 1.25
Mark old annotations as such in the merge, so we don't log all of htem.
Mon Jan 10 22:56:49 2005 UTC (15 years ago) by olson
Changes since 1.24: +62 -8 lines
Diff to previous 1.24
Add code for gating whether assignments are accepted.
Mon Jan 10 13:15:00 2005 UTC (15 years ago) by olson
Changes since 1.23: +18 -10 lines
Diff to previous 1.23
Use AnyDBM_File instead of DB_File for portability.
Fri Jan 7 22:41:43 2005 UTC (15 years ago) by olson
Changes since 1.22: +53 -5 lines
Diff to previous 1.22
More P2P fixes; fix up html logging.
Fri Jan 7 19:24:39 2005 UTC (15 years ago) by olson
Changes since 1.21: +42 -12 lines
Diff to previous 1.21
assorted tweaks.
Fri Jan 7 18:54:45 2005 UTC (15 years ago) by olson
Changes since 1.20: +404 -255 lines
Diff to previous 1.20
some refactoring
Thu Jan 6 04:37:54 2005 UTC (15 years ago) by olson
Changes since 1.19: +72 -14 lines
Diff to previous 1.19
more updates.
Wed Jan 5 22:10:06 2005 UTC (15 years ago) by olson
Changes since 1.18: +282 -6 lines
Diff to previous 1.18
more fixes for p2p mirroring.
Wed Jan 5 16:19:44 2005 UTC (15 years ago) by olson
Changes since 1.17: +24 -5 lines
Diff to previous 1.17
p2p changes.
Mon Dec 6 18:26:25 2004 UTC (15 years, 1 month ago) by olson
Changes since 1.16: +5 -3 lines
Diff to previous 1.16
Add a timeout and some debugging.
Mon Oct 4 15:57:15 2004 UTC (15 years, 3 months ago) by olson
fix typo
Mon Oct 4 15:56:29 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.14: +205 -4 lines
More updates.
Fri Sep 24 20:10:38 2004 UTC (15 years, 3 months ago) by olson
more testing
Fri Sep 24 20:09:56 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.12: +34 -4 lines
more testing
Fri Sep 24 19:52:25 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.11: +7 -2 lines
more testing
Fri Sep 24 19:48:17 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.10: +1 -2 lines
more testing
Fri Sep 24 19:36:27 2004 UTC (15 years, 3 months ago) by olson
more testing
Fri Sep 24 19:35:48 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.8: +22 -1 lines
more testing
Fri Sep 24 19:13:13 2004 UTC (15 years, 3 months ago) by olson
more testing
Fri Sep 24 18:58:42 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.6: +38 -4 lines
Possible fix for beg_of and contig_of
More p2p stuff
Fri Sep 24 18:34:32 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.5: +90 -3 lines
Some contig manipulation stuff, more p2p stuff.
Wed Sep 22 20:41:39 2004 UTC (15 years, 4 months ago) by olson
test
Wed Sep 22 20:40:05 2004 UTC (15 years, 4 months ago) by olson
test
Wed Sep 22 20:39:01 2004 UTC (15 years, 4 months ago) by olson
uncripple mapping
Wed Sep 22 19:33:35 2004 UTC (15 years, 4 months ago) by olson
add dbug
Wed Sep 22 19:29:51 2004 UTC (15 years, 4 months ago) by olson
Mods for P2P update stuff.
