[Bio] / FigKernelPackages / Overlap.pm Repository:
Log of /FigKernelPackages/Overlap.pm
Links to caBIG-00-00-00: (view) (download) (as text) (annotate)
Sun Jul 31 16:59:31 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.1: +8 -0 lines
Modified CheckOverlap to allow full locations as input.
Tue Jul 26 20:10:59 2005 UTC (14 years, 8 months ago) by parrello
Added a new object to track information related to overlapping gene calls.
