[Bio] / FigKernelPackages / NCBI_genetic_code.pm Repository:
Log of /FigKernelPackages/NCBI_genetic_code.pm
Wed Feb 13 21:04:24 2019 UTC (15 months, 2 weeks ago) by gdpusch
CVS Tags: HEAD
Changes since 1.6: +73 -1 lines
Added genetic codes 24 through 33.
Wed Jul 19 23:30:22 2017 UTC (2 years, 10 months ago) by golsen
Changes since 1.5: +11 -19 lines
Added code "0", which is the universal code with the 3 common bacterial
and archaeal initiator codons.
Wed Apr 22 16:54:56 2015 UTC (5 years, 1 month ago) by golsen
Changes since 1.4: +18 -9 lines
Introduce code zero, which is the standard code with the most common
bacterial and archaeal initiators, rather than the huge list in code 11.
Sun Mar 4 00:51:51 2012 UTC (8 years, 2 months ago) by golsen
CVS Tags: mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.3: +63 -19 lines
Add start codons to genetic code data.
Fri Aug 27 19:32:22 2010 UTC (9 years, 9 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, myrast_33, myrast_rel40, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.2: +5 -0 lines
add SAS header
Fri Nov 23 21:59:40 2007 UTC (12 years, 6 months ago) by golsen
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_release_2008_09_29
Changes since 1.1: +32 -14 lines
Some minor changes and add the FIG header.
Fri Nov 23 21:47:55 2007 UTC (12 years, 6 months ago) by golsen
Simple interfaces to the NCBI numbered translation tables (for all of their
codes).  The data are plain text, and hence are easily updated or appended
to.
