[Bio] / FigKernelPackages / NCBI_genetic_code.pm Repository:
View of /FigKernelPackages/NCBI_genetic_code.pm
Revision 1.3 - (download) (as text) (annotate)
Fri Aug 27 19:32:22 2010 UTC (9 years, 9 months ago) by olson
CVS Tags: mgrast_dev_08112011, mgrast_dev_08022011, myrast_rel40, mgrast_dev_05262011, mgrast_dev_04082011, rast_rel_2010_0928, mgrast_dev_12152011, mgrast_dev_06072011, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2011_0119, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, mgrast_dev_04012011, myrast_33, rast_rel_2011_0928, mgrast_dev_04052011, mgrast_dev_02222011, mgrast_dev_10262011
Changes since 1.2: +5 -0 lines
add SAS header
# This is a SAS component
# Copyright (c) 2003-2007 University of Chicago and Fellowship
# Public License.
package NCBI_genetic_code;
#  Access to the numbered genetic codes used by NCBI.  A code is returned
#  as a reference to a hash that has both uppercase and lowercase translations.
#  There are two access methods: by hash element and by subroutine:
#   \%genetic_code_n = $NCBI_genetic_code::genetic_code{ $n };
#   \%genetic_code_n =  NCBI_genetic_code::genetic_code( $n );
#  The only difference in behaviour is that the subroutine defaults to code
#  number 1 when no parameter is supplied:
#   \%genetic_code_1 =  NCBI_genetic_code::genetic_code();
#  All other invalid numbers return an undefined value.
use strict;
my @nt = qw( T C A G );  #  The order here must match that in the tables
my ( $nt1, $nt12 );
my @triplets = map { $nt1 = $_;
                     map { $nt12 = $nt1 . $_;
                           map { $nt12 . $_ } @nt
                         } @nt
                   } @nt;
my $code_num;
our %genetic_code = map { my @aas = split //, $_->[1];
                          $_->[0] => { map { @$_, map { lc } @$_ }   # uc and lc
                                       map { [ $_ => shift @aas ] }  # assignment
                                       @triplets                     # codons
                    map { if ( /transl_table=(\d+)/ ) { $code_num = $1 };
                          /AAs\s+=\s+(\S+)/ ? [ $code_num, $1 ] : ()
                    split /\n/, <<'End_of_Codes';
1. The Standard Code (transl_table=1)
    AAs  = FFLLSSSSYY**CC*WLLLLPPPPHHQQRRRRIIIMTTTTNNKKSSRRVVVVAAAADDEEGGGG
  Starts = ---M---------------M---------------M----------------------------
  Base1  = TTTTTTTTTTTTTTTTCCCCCCCCCCCCCCCCAAAAAAAAAAAAAAAAGGGGGGGGGGGGGGGG
  Base2  = TTTTCCCCAAAAGGGGTTTTCCCCAAAAGGGGTTTTCCCCAAAAGGGGTTTTCCCCAAAAGGGG
  Base3  = TCAGTCAGTCAGTCAGTCAGTCAGTCAGTCAGTCAGTCAGTCAGTCAGTCAGTCAGTCAGTCAG
2. The Vertebrate Mitochondrial Code (transl_table=2)
    AAs  = FFLLSSSSYY**CCWWLLLLPPPPHHQQRRRRIIMMTTTTNNKKSS**VVVVAAAADDEEGGGG
  Starts = --------------------------------MMMM---------------M------------
3. The Yeast Mitochondrial Code (transl_table=3)
    AAs  = FFLLSSSSYY**CCWWTTTTPPPPHHQQRRRRIIMMTTTTNNKKSSRRVVVVAAAADDEEGGGG
  Starts = ----------------------------------MM----------------------------
4. The Mold, Protozoan, and Coelenterate Mitochondrial Code and the Mycoplasma/Spiroplasma Code (transl_table=4)
    AAs  = FFLLSSSSYY**CCWWLLLLPPPPHHQQRRRRIIIMTTTTNNKKSSRRVVVVAAAADDEEGGGG
  Starts = --MM---------------M------------MMMM---------------M------------
5. The Invertebrate Mitochondrial Code (transl_table=5)
    AAs  = FFLLSSSSYY**CCWWLLLLPPPPHHQQRRRRIIMMTTTTNNKKSSSSVVVVAAAADDEEGGGG
  Starts = ---M----------------------------MMMM---------------M------------
6. The Ciliate, Dasycladacean and Hexamita Nuclear Code (transl_table=6)
    AAs  = FFLLSSSSYYQQCC*WLLLLPPPPHHQQRRRRIIIMTTTTNNKKSSRRVVVVAAAADDEEGGGG
  Starts = -----------------------------------M----------------------------
9. The Echinoderm and Flatworm Mitochondrial Code (transl_table=9)
    AAs  = FFLLSSSSYY**CCWWLLLLPPPPHHQQRRRRIIIMTTTTNNNKSSSSVVVVAAAADDEEGGGG
  Starts = -----------------------------------M---------------M------------
10. The Euplotid Nuclear Code (transl_table=10)
    AAs  = FFLLSSSSYY**CCCWLLLLPPPPHHQQRRRRIIIMTTTTNNKKSSRRVVVVAAAADDEEGGGG
11. The Bacterial and Plant Plastid Code (transl_table=11)
  Starts = ---M---------------M------------MMMM---------------M------------
12. The Alternative Yeast Nuclear Code (transl_table=12)
    AAs  = FFLLSSSSYY**CC*WLLLSPPPPHHQQRRRRIIIMTTTTNNKKSSRRVVVVAAAADDEEGGGG
  Starts = -------------------M---------------M----------------------------
13. The Ascidian Mitochondrial Code (transl_table=13)
    AAs  = FFLLSSSSYY**CCWWLLLLPPPPHHQQRRRRIIMMTTTTNNKKSSGGVVVVAAAADDEEGGGG
  Starts = ---M------------------------------MM---------------M------------
14. The Alternative Flatworm Mitochondrial Code (transl_table=14)
    AAs  = FFLLSSSSYYY*CCWWLLLLPPPPHHQQRRRRIIIMTTTTNNNKSSSSVVVVAAAADDEEGGGG
15. Blepharisma Nuclear Code (transl_table=15)
    AAs  = FFLLSSSSYY*QCC*WLLLLPPPPHHQQRRRRIIIMTTTTNNKKSSRRVVVVAAAADDEEGGGG
16. Chlorophycean Mitochondrial Code (transl_table=16)
    AAs  = FFLLSSSSYY*LCC*WLLLLPPPPHHQQRRRRIIIMTTTTNNKKSSRRVVVVAAAADDEEGGGG
21. Trematode Mitochondrial Code (transl_table=21)
    AAs  = FFLLSSSSYY**CCWWLLLLPPPPHHQQRRRRIIMMTTTTNNNKSSSSVVVVAAAADDEEGGGG
22. Scenedesmus obliquus mitochondrial Code (transl_table=22)
    AAs  = FFLLSS*SYY*LCC*WLLLLPPPPHHQQRRRRIIIMTTTTNNKKSSRRVVVVAAAADDEEGGGG
23. Thraustochytrium Mitochondrial Code (transl_table=23)
    AAs  = FF*LSSSSYY**CC*WLLLLPPPPHHQQRRRRIIIMTTTTNNKKSSRRVVVVAAAADDEEGGGG
  Starts = --------------------------------M--M---------------M------------
End_of_Codes
sub genetic_code { $genetic_code{ $_[0] || '1' } }
1;
