[Bio] / FigKernelPackages / KGML.pm Repository:
Log of /FigKernelPackages/KGML.pm
Tue May 15 21:12:18 2007 UTC (12 years, 6 months ago) by olson
Changes since 1.3: +13 -0 lines
Hope college modifications.
Wed Dec 7 19:38:22 2005 UTC (14 years ago) by golsen
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one.  Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
Added license words.
Fri Sep 9 14:47:56 2005 UTC (14 years, 3 months ago) by dejongh
CGIs, Perl modules, and help page to support KEGG integration into subsystems page; work done at Hope College during Summer 2005 REU project
