[Bio] / FigKernelPackages / JobScheduler.pm Repository:
Log of /FigKernelPackages/JobScheduler.pm
Tue Feb 5 01:59:10 2008 UTC (12 years ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_release_2008_09_29
Changes since 1.7: +9 -6 lines
Changed POD headers to work better with the new system.
Wed Mar 29 20:41:33 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.6: +1 -0 lines
Add support for readonly database instance, and for FileLocking module.
Added license words.
Sun Jul 10 01:05:36 2005 UTC (14 years, 7 months ago) by redwards
CVS Tags: caBIG-00-00-00, caBIG-dataload-0, merge-trunktag-bodev_news-3
Changes since 1.4: +18 -0 lines
Allow deleting jobs from seed_ctl.cgi
Tue May 17 16:04:08 2005 UTC (14 years, 9 months ago) by olson
Wed May 4 21:42:50 2005 UTC (14 years, 9 months ago) by olson
Changes since 1.2: +3 -2 lines
Fri Dec 17 23:20:56 2004 UTC (15 years, 2 months ago) by olson
Changes since 1.1: +5 -3 lines
More subsystem/p2p fixes.
Mon Dec 6 18:31:40 2004 UTC (15 years, 2 months ago) by olson
Add job scheduler code.
