[Bio] / FigKernelPackages / JobScheduler.pm Repository:
Diff of /FigKernelPackages/JobScheduler.pm
revision 1.2, Fri Dec 17 23:20:56 2004 UTC revision 1.3, Wed May 4 21:42:50 2005 UTC
# Line 1  Line 1
1  #  #
2  # This is a simple job scheduler, built for the SEED environment.  # This is a simple job scheduler, built for the SEED environment.
3  #  #
4  # A job queue is maintained in the directory $FIG_Config::data/JobQueue.  # A job queue is maintained in the directory $FIG_Config::fig/var/JobQueue.
5  #  #
6  # Each entry in the queue is a directory named J_XXXX where J_XXXX is the job ID.  # Each entry in the queue is a directory named J_XXXX where J_XXXX is the job ID.
7  #  #
# Line 53  Line 53
53  {  {
54      my($class, $dir) = @_;      my($class, $dir) = @_;
55
56      $dir = "$FIG_Config::data/JobQueue" unless $dir;      $dir = "$FIG_Config::fig/var/JobQueue" unless $dir;
57
58        &FIG::verify_dir("$FIG_Config::fig/var");
59      warn "Scheduler using $dir\n";      warn "Scheduler using $dir\n";
60      &FIG::verify_dir($dir);      &FIG::verify_dir($dir);
61
Legend:
Removed from v.1.2
changed lines
  Added in v.1.3
