[Bio] / FigKernelPackages / InterfaceRoutines.pm Repository:
Log of /FigKernelPackages/InterfaceRoutines.pm
Tue Oct 10 18:37:14 2006 UTC (13 years, 3 months ago) by olson
Changes since 1.11: +8 -1 lines
readonly fixes; seed-run-job update to run from input file
Changes since 1.10: +17 -0 lines
Added license words.
Wed Aug 17 01:20:14 2005 UTC (14 years, 5 months ago) by overbeek
show curator of subsystem on protein page
Tue Jul 26 20:10:25 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.8: +5 -2 lines
Added trace messages for tracking down annotation problems.
Sun Jul 17 19:04:27 2005 UTC (14 years, 6 months ago) by redwards
Changes since 1.7: +6 -6 lines
Making attributes interface work
Tue Jul 12 14:34:14 2005 UTC (14 years, 6 months ago) by redwards
Changing attributes and modifying protein.cgi with show/hides
Wed Jun 29 00:28:01 2005 UTC (14 years, 6 months ago) by redwards
CVS Tags: merge-trunktag-bobdev_news-2
Changes since 1.5: +19 -0 lines
Initial release of proteinfamilies.cgi into the wild
Tue Jun 28 18:46:43 2005 UTC (14 years, 6 months ago) by overbeek
add tigr links
Mon Jun 27 20:00:55 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.3: +0 -39 lines
after Sprout runs
Thu Jun 23 21:24:48 2005 UTC (14 years, 6 months ago) by overbeek
CVS Tags: merge-trunktag-bobdev_news-1
Changes since 1.2: +8 -24 lines
finally
Wed Jun 22 21:01:02 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.1: +37 -37 lines
Replaced tabs with spaces to make indenting device-independent.
Mon Jun 13 19:44:32 2005 UTC (14 years, 7 months ago) by overbeek
CVS Tags: Root-bobdev_news
interface routines hack
