[Bio] / FigKernelPackages / InsertIntoTree.pm Repository:
Log of /FigKernelPackages/InsertIntoTree.pm
Thu Oct 4 00:58:56 2007 UTC (12 years, 3 months ago) by overbeek
Changes since 1.14: +12 -1 lines
check figfams fixes
Sun Feb 11 18:51:50 2007 UTC (12 years, 11 months ago) by golsen
Changes since 1.13: +461 -77 lines
A total rewrite of this package to provide more general interface to
routines that support adding new sequences to an old tree.
Sun Feb 11 18:25:48 2007 UTC (12 years, 11 months ago) by golsen
Changes since 1.12: +69 -12 lines
New functions for making big trees.
Mon Jan 29 23:13:27 2007 UTC (12 years, 11 months ago) by overbeek
Changes since 1.11: +14 -4 lines
bring tree insertion up to date
Mon Jan 29 22:55:24 2007 UTC (12 years, 11 months ago) by golsen
Changes since 1.10: +32 -114 lines
Improved packaging of insert functions.
Fri Jan 12 18:45:24 2007 UTC (13 years ago) by overbeek
Changes since 1.9: +2 -4 lines
Remove use File::mkstemp. Interfers with creation of new temp files
Thu Jan 11 19:59:54 2007 UTC (13 years ago) by overbeek
delete temp directories in phylogeny tools
Tue Jan 9 20:38:26 2007 UTC (13 years ago) by overbeek
Changes since 1.7: +6 -1 lines
Adding mktemp and host to generate unique names
Tue Jan 9 19:27:41 2007 UTC (13 years ago) by overbeek
use /tmp rather than FIG/Tmp for cluster work
Mon Jan 8 19:47:28 2007 UTC (13 years ago) by overbeek
Changes since 1.5: +10 -8 lines
add tree_neighbors and latest phylogeny stuff
Sat Jan 6 17:39:41 2007 UTC (13 years ago) by overbeek
Changes since 1.4: +14 -5 lines
make sure tree insertion code is all committed
Fri Jan 5 02:13:04 2007 UTC (13 years ago) by overbeek
Changes since 1.3: +6 -0 lines
add make_neigh_joining_tree and make_proml_tree
Wed Dec 20 15:30:19 2006 UTC (13 years, 1 month ago) by overbeek
add bring_tree_up_to_ali
Fri Dec 15 00:46:54 2006 UTC (13 years, 1 month ago) by overbeek
Changes since 1.1: +11 -1 lines
add checkpoints to insertion into trees
Fri Dec 15 00:09:52 2006 UTC (13 years, 1 month ago) by overbeek
add ability to insert sequences into a tree
