[Bio] / FigKernelPackages / HTML.py Repository:
Log of /FigKernelPackages/HTML.py
Mon Dec 5 19:06:30 2005 UTC (14 years, 4 months ago) by olson
Added license words.
Fri Apr 15 23:07:20 2005 UTC (14 years, 11 months ago) by olson
anther dumb typo
Fri Apr 15 23:06:59 2005 UTC (14 years, 11 months ago) by olson
dumb typo
Fri Apr 15 23:05:05 2005 UTC (14 years, 11 months ago) by olson
fix hdr
Fri Apr 15 23:03:03 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.1: +27 -20 lines
Pure python HTML.compute_html_header()
Fri Feb 18 19:31:12 2005 UTC (15 years, 1 month ago) by olson
Add support for using HTML.pm from python.
Note we needed to add
    shift if UNIVERSAL::isa($_[0],__PACKAGE__);
to the functions in HTML.pm because they're used as methods when called from python.
