[Bio] / FigKernelPackages / GenomeTypeObject.pm Repository:
Log of /FigKernelPackages/GenomeTypeObject.pm
Mon Aug 27 23:00:18 2018 UTC (19 months ago) by olson
CVS Tags: HEAD
Changes since 1.45: +9 -0 lines
Diff to previous 1.45
Merge bob version
Tue Aug 21 20:54:19 2018 UTC (19 months, 1 week ago) by parrello
Changes since 1.44: +36 -0 lines
Diff to previous 1.44
Changes copied from SEEDtk project.
Wed Mar 28 03:11:40 2018 UTC (2 years ago) by olson
Changes since 1.43: +41 -9 lines
Diff to previous 1.43
Fixes
Mon May 15 19:38:26 2017 UTC (2 years, 10 months ago) by parrello
Changes since 1.42: +4 -25 lines
Diff to previous 1.42
Tue Feb 21 21:05:57 2017 UTC (3 years, 1 month ago) by parrello
Changes since 1.41: +181 -28 lines
Diff to previous 1.41
Sat Apr 16 02:55:56 2016 UTC (3 years, 11 months ago) by parrello
Changes since 1.40: +4 -4 lines
Diff to previous 1.40
Fri Jan 22 19:17:07 2016 UTC (4 years, 2 months ago) by olson
Changes since 1.39: +25 -1 lines
Diff to previous 1.39
Fix for incorrectly initialized genome objects.
Thu Oct 15 20:44:30 2015 UTC (4 years, 5 months ago) by olson
Changes since 1.38: +33 -18 lines
Diff to previous 1.38
Expose sorted_features method. make renumber_features use that, and don't make the renumber dependent on sorting by feature type first.
Thu Oct 15 19:23:08 2015 UTC (4 years, 5 months ago) by olson
Changes since 1.37: +50 -0 lines
Diff to previous 1.37
add bounds() and flattened_feature_aliases()
Fri Oct 9 21:12:37 2015 UTC (4 years, 5 months ago) by olson
Changes since 1.36: +22 -8 lines
Diff to previous 1.36
When renumbering use the type in the identifier, not the type field.
Fri Oct 9 20:09:44 2015 UTC (4 years, 5 months ago) by olson
Changes since 1.35: +5 -5 lines
Diff to previous 1.35
Change hostname cached value key to start with _ so cleared before writing.
Fix error message for mismatched feature counts.
Mon Aug 31 23:13:33 2015 UTC (4 years, 7 months ago) by golsen
Changes since 1.34: +143 -70 lines
Diff to previous 1.34
Break out the id generation from the rest of the add feature code
(there are multiple comments in the code as to why).
Improve condistency of time resolution on time stamps (use Time::HiRes).
Tue Aug 25 17:55:21 2015 UTC (4 years, 7 months ago) by parrello
Changes since 1.33: +18 -18 lines
Diff to previous 1.33
Fri Aug 7 18:52:06 2015 UTC (4 years, 7 months ago) by golsen
Changes since 1.32: +2 -11 lines
Diff to previous 1.32
Slight clean-up on add_contig.
Fri Aug 7 17:55:23 2015 UTC (4 years, 7 months ago) by olson
Changes since 1.31: +1 -1 lines
Diff to previous 1.31
another fix
Fri Aug 7 17:52:50 2015 UTC (4 years, 7 months ago) by olson
Changes since 1.30: +0 -4 lines
Diff to previous 1.30
Fix contig indexing bug
Fri Jul 10 17:12:01 2015 UTC (4 years, 8 months ago) by golsen
Changes since 1.29: +797 -58 lines
Diff to previous 1.29
More sanity checks and access functions for GenomeTypeObjects.
Tue Jun 9 17:55:42 2015 UTC (4 years, 9 months ago) by olson
Changes since 1.28: +2 -2 lines
Diff to previous 1.28
Fix min bug.
Fri May 29 21:10:13 2015 UTC (4 years, 10 months ago) by olson
Changes since 1.27: +3 -2 lines
Diff to previous 1.27
add -id_type to add_feature
Thu May 28 14:54:39 2015 UTC (4 years, 10 months ago) by olson
Changes since 1.26: +2 -1 lines
Diff to previous 1.26
Add owner field.
Wed May 27 20:57:15 2015 UTC (4 years, 10 months ago) by olson
Changes since 1.25: +11 -0 lines
Diff to previous 1.25
Add fig| prefix to naked genome IDs.
Fri Apr 24 20:31:44 2015 UTC (4 years, 11 months ago) by parrello
Changes since 1.24: +26 -0 lines
Diff to previous 1.24
Fri Apr 10 15:30:46 2015 UTC (4 years, 11 months ago) by parrello
Changes since 1.23: +245 -243 lines
Diff to previous 1.23
Wed Mar 25 04:58:26 2015 UTC (5 years ago) by parrello
Changes since 1.22: +46 -32 lines
Diff to previous 1.22
Added destroy_to_file. Fixed error in analysis_event_id.
Wed Feb 25 20:24:20 2015 UTC (5 years, 1 month ago) by olson
Diff to previous 1.21
Update fields for genome metadata.
Sun Sep 28 17:31:30 2014 UTC (5 years, 6 months ago) by olson
Changes since 1.20: +123 -2 lines
Diff to previous 1.20
Add renumber
Thu Sep 18 16:14:36 2014 UTC (5 years, 6 months ago) by olson
Changes since 1.19: +8 -0 lines
Diff to previous 1.19
Fixes for IS.
Mon Aug 18 20:41:28 2014 UTC (5 years, 7 months ago) by olson
CVS Tags: rast_rel_2014_0912
Changes since 1.18: +22 -0 lines
Diff to previous 1.18
Add gc computation.
Tue Jul 29 16:49:08 2014 UTC (5 years, 8 months ago) by olson
CVS Tags: rast_rel_2014_0729
Changes since 1.17: +5 -2 lines
Diff to previous 1.17
write to alternate assigned_functions file if presented in options
Mon Jul 28 20:48:10 2014 UTC (5 years, 8 months ago) by olson
Changes since 1.16: +18 -1 lines
Diff to previous 1.16
add filtering on writing of sequence data
Mon Jul 14 20:29:40 2014 UTC (5 years, 8 months ago) by olson
Changes since 1.15: +29 -1 lines
Genome object read/write to seed dir changes.
Fri Jul 11 21:47:48 2014 UTC (5 years, 8 months ago) by olson
Changes since 1.14: +13 -0 lines
Add annotations.
Fri Jul 11 21:23:43 2014 UTC (5 years, 8 months ago) by olson
Changes since 1.13: +84 -43 lines
Expand the funtionality of write_seed_dir.
Wed Jun 18 21:09:45 2014 UTC (5 years, 9 months ago) by olson
Changes since 1.12: +2 -1 lines
another bug fix
Wed Jun 18 20:44:16 2014 UTC (5 years, 9 months ago) by olson
Changes since 1.11: +7 -5 lines
Fix bug in add_features_from_list
Thu May 8 21:29:59 2014 UTC (5 years, 10 months ago) by olson
Changes since 1.10: +14 -4 lines
Fix bug in the case where GenomeTypeObject::prepare_For_Return is called as a sub not a method
Wed May 7 19:11:51 2014 UTC (5 years, 10 months ago) by olson
fix nasty little typo
Wed May 7 19:11:14 2014 UTC (5 years, 10 months ago) by overbeek
Changes since 1.8: +39 -0 lines
Add methods.
Tue May 6 20:01:13 2014 UTC (5 years, 10 months ago) by olson
Changes since 1.7: +17 -2 lines
Remove requirement for Data::Structure::Util.
Thu May 1 19:00:46 2014 UTC (5 years, 11 months ago) by olson
Changes since 1.6: +209 -12 lines
Modifications for new RAST2 services.
Mon Mar 24 15:27:57 2014 UTC (6 years ago) by olson
Changes since 1.5: +31 -4 lines
Use either UUID or Data::UUID.
Thu Feb 20 22:50:57 2014 UTC (6 years, 1 month ago) by olson
Changes since 1.4: +140 -0 lines
Add contig index.
Add get_feature_dna
Add write_temp_seed_dir
Add create_from_file constructor.
Tue Jan 7 19:21:59 2014 UTC (6 years, 2 months ago) by olson
Changes since 1.3: +24 -15 lines
Add support to add_feature for passing in a precomputed id - so we can do batch assignment of ids before
we get here.
Mon Jan 6 21:11:56 2014 UTC (6 years, 2 months ago) by olson
Changes since 1.2: +121 -2 lines
modifications for new rast2 code
Tue Sep 3 20:35:06 2013 UTC (6 years, 7 months ago) by gdpusch
Changes since 1.1: +22 -10 lines
Added translation and ID-server support.
Mon Aug 5 22:56:12 2013 UTC (6 years, 7 months ago) by gdpusch
Initial checkin
