[Bio] / FigKernelPackages / GenomeMetaDB.pm Repository:
Log of /FigKernelPackages/GenomeMetaDB.pm
Wed Aug 5 15:05:02 2009 UTC (10 years, 8 months ago) by jared
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.4: +7 -0 lines
added update_path
Sun Mar 15 23:54:28 2009 UTC (11 years ago) by parrello
CVS Tags: rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09
Fixed an error in the POD documentation. Fixed a compiler warning.
Mon Oct 20 19:14:58 2008 UTC (11 years, 5 months ago) by olson
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05
Changes since 1.2: +6 -0 lines
Fix database version of GenomeMeta's get_log output to match the old format, so we can actually see logfiles.
Fri Sep 5 15:23:44 2008 UTC (11 years, 7 months ago) by olson
Changes since 1.1: +8 -6 lines
touch the meta file when a change is written to the db.
Fri Jun 20 21:34:01 2008 UTC (11 years, 9 months ago) by olson
oops, these need updated.
