[Bio] / FigKernelPackages / GenomeLists.pm Repository:
Log of /FigKernelPackages/GenomeLists.pm
Links to mgrast_rel_2008_0923: (view) (download) (as text) (annotate)
Wed Dec 19 22:31:54 2007 UTC (12 years, 2 months ago) by bartels
Changes since 1.1: +8 -0 lines
put in verify_dir so that the directory is produced automatically
if you access it for the first time
CVS
Mon Nov 19 21:10:00 2007 UTC (12 years, 3 months ago) by bartels
Diff to selected 1.2
