[Bio] / FigKernelPackages / FullLocation.pm Repository:
Log of /FigKernelPackages/FullLocation.pm
Wed Nov 25 21:01:46 2009 UTC (10 years ago) by parrello
Changes since 1.24: +21 -0 lines
Diff to previous 1.24
Added a method to compute the total location length.
Tue Jun 17 20:42:53 2008 UTC (11 years, 5 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_release_2008_09_29
Changes since 1.23: +13 -2 lines
Diff to previous 1.23
Fix translation gunk.
Wed May 14 09:07:39 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: rast_rel_2008_06_16
Changes since 1.22: +5 -6 lines
Diff to previous 1.22
Changed the name of the Constrain function to avoid a naming conflict. Fixed a comment.
Tue Apr 29 05:32:10 2008 UTC (11 years, 7 months ago) by parrello
Changes since 1.21: +2 -3 lines
Diff to previous 1.21
Fixed the pod docs.
Tue Feb 5 01:51:44 2008 UTC (11 years, 10 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.20: +255 -235 lines
Diff to previous 1.20
Added new support for gene boundary methods.
Fri Jan 25 20:19:50 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.19: +8 -2 lines
Diff to previous 1.19
Fixed so that the location is not changed if  pick-gene-boundaries call fails.
Fri Jan 25 18:53:35 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.18: +21 -12 lines
Diff to previous 1.18
Changed PickGeneBoundaries to use option-style parameters. Added tracing for search failures at level 3.
Thu Jan 24 04:19:14 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.17: +39 -28 lines
Diff to previous 1.17
Changed PickGeneBoundaries to allow specification of a location as a search limit and to fail if one of the searches fails.
Sat Jan 19 06:03:34 2008 UTC (11 years, 10 months ago) by parrello
Diff to previous 1.16
Fixed an even stupider bug.
Sat Jan 19 05:57:22 2008 UTC (11 years, 10 months ago) by parrello
Fixed a stupid error.
Sat Jan 19 05:54:47 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.14: +28 -34 lines
Fixed PickGeneBoundaries to recover more gracefully when unable to find a stop codon.
Sat Jan 19 03:46:33 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.13: +332 -99 lines
Revamped DNA searching to be more compatible with the requirements of picking gene boundaries. Extended to allow for specifying translation codes in the constructor.
Fri Jan 18 23:11:02 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.12: +152 -175 lines
Replaced Search so that it does what the documentation says, which is to stop searching at the specified limit. Added the ability to omit the limit and simply search to the end of the location.
Thu Dec 6 13:59:34 2007 UTC (12 years ago) by parrello
Changes since 1.11: +20 -20 lines
Mon Jun 11 17:27:54 2007 UTC (12 years, 6 months ago) by parrello
Removed a FIG dependency that was causing duplicate-method warnings.
Changes since 1.9: +17 -0 lines
Added license words.
Sat Sep 10 07:38:44 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.8: +183 -92 lines
Fixed the Search method to handle cases where it must search more than 9000 base pairs.
Mon Aug 8 17:24:27 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.7: +7 -6 lines
Fixed a bug in the section of "ExtremeCodon" that adjusts to the trailing edge of a codon.
Mon Aug 8 03:59:19 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.6: +11 -4 lines
Fixed an error in "Search" that goofed things up if the desired codon pattern was not found.
Fri Aug 5 17:43:53 2005 UTC (14 years, 4 months ago) by overbeek
fix bad bug in calling starts
Sun Jul 31 16:29:33 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.4: +44 -16 lines
Updated the Extend method to allow extending inward.
Sun Jul 31 00:40:24 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.3: +33 -4 lines
Fixed a bug in the handling of ExtremeCodon when the direction is to the right.
Sat Jul 30 23:53:16 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.2: +49 -0 lines
Added new ExtremeCodon method.
Wed Jul 27 19:43:33 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.1: +216 -26 lines
Added new methods for extracting codon DNA and accessing points near each end of a location.
Tue Jul 26 20:07:58 2005 UTC (14 years, 4 months ago) by parrello
Added new FullLocation object for manipulation sequences of locations.
