[Bio] / FigKernelPackages / FudgeTransactions.pm Repository:
Log of /FigKernelPackages/FudgeTransactions.pm
Thu Dec 6 13:59:34 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.3: +9 -9 lines
Wed Dec 7 19:38:22 2005 UTC (14 years, 2 months ago) by golsen
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one.  Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
Added license words.
Thu Sep 1 09:35:43 2005 UTC (14 years, 5 months ago) by parrello
Cleaned up the transaction-processing stuff.
