[Bio] / FigKernelPackages / FileLocking.pm Repository:
Log of /FigKernelPackages/FileLocking.pm
Tue Aug 10 19:38:47 2010 UTC (9 years, 3 months ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.3: +10 -1 lines
Changes for DesktopRast.
CVHnS: ----------------------------------------------------------------------
Tue Feb 16 21:56:33 2010 UTC (9 years, 9 months ago) by olson
CVS Tags: rast_rel_2010_0526
Changes since 1.2: +75 -22 lines
Add support for File::FcntlLock
Wed Sep 5 21:00:42 2007 UTC (12 years, 2 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_release_2008_09_29
Changes since 1.1: +11 -2 lines
add shared locking
Wed Mar 29 20:41:33 2006 UTC (13 years, 7 months ago) by overbeek
Add support for readonly database instance, and for FileLocking module.
