[Bio] / FigKernelPackages / FileIOFunctions.pm Repository:
Diff of /FigKernelPackages/FileIOFunctions.pm
revision 1.13, Fri May 7 18:51:30 2010 UTC revision 1.14, Thu May 13 05:05:19 2010 UTC
# Line 638  Line 638
638          return $OriginalNumber;          return $OriginalNumber;
639  }  }
640
 sub ConvertToSearchNames {
         my ($InName) = @_;
         if ($InName =~ m/-$/) {
                 return $InName;
         #I convert all names to lowercase to help with matching
         $InName = lc($InName);
         #I remove all spaces from all names to help with matching
         $InName =~ s/\s//g;
         $InName =~ s/,//g;
         $InName =~ s/-//g;
         $InName =~ s/_//g;
         $InName =~ s/\(//g;
         $InName =~ s/\)//g;
         $InName =~ s/\[//g;
         $InName =~ s/\]//g;
         $InName =~ s/\://g;
         $InName =~ s///g;
         $InName =~ s/'//g;
         $InName =~ s/\;//g;
         my $NameOne = $InName;
         $InName =~ s/icacid/ate/g;
         if ($NameOne eq $InName) {
                 return ($NameOne);
         } else {
                 return ($NameOne,$InName);
 sub ConvertToNeutralFormula {
         my ($NeutralFormula,$Charge) = @_;
         if (!defined($NeutralFormula)) {
                 $NeutralFormula = "";
         } elsif ($NeutralFormula eq "H") {
                 #Do nothing
         } elsif (defined($Charge) && $Charge ne "0") {
                 my $CurrentH = 0;
                 if ($NeutralFormula =~ m/H(\d+)/) {
                         $CurrentH = $1;
                 } elsif ($NeutralFormula =~ m/H[A-Z]/ || $NeutralFormula =~ m/H$/) {
                         $CurrentH = 1;
                 my $NewH = $CurrentH;
                 if ($Charge >= $CurrentH) {
                         $NewH = 0;
                 } else {
                         $NewH = $CurrentH - $Charge;
                 my $Replace = "H";
                 if ($NewH > 1) {
                         $Replace = "H".$NewH;
                 } elsif ($NewH == 0) {
                         $Replace = "";
                 if ($CurrentH == 0 && $NewH > 0) {
                         $NeutralFormula .= "H";
                         if ($NewH > 1) {
                                 $NeutralFormula .= $NewH;
                 } elsif ($CurrentH == 1) {
                         $NeutralFormula =~ s/H$/$Replace/;
                         $NeutralFormula =~ s/H([A-Z])/$Replace$1/;
                 } else {
                         my $Match = "H".$CurrentH;
                         $NeutralFormula =~ s/$Match/$Replace/;
         return $NeutralFormula;
641  sub CountFileLines {  sub CountFileLines {
642          my ($filename) = @_;          my ($filename) = @_;
643          my $lines = 0;          my $lines = 0;
# Line 774  Line 699
699          return ($StandardFormula,$CompareFormula);          return ($StandardFormula,$CompareFormula);
700  }  }
701
702  sub ParseGPRFile {  sub ParseGPRFile {
703          my ($Filename,$ReactionData) = @_;          my ($Filename,$ReactionData) = @_;
704
Legend:
Removed from v.1.13
changed lines
  Added in v.1.14
