[Bio] / FigKernelPackages / FigGFF.pm Repository:
Log of /FigKernelPackages/FigGFF.pm
Fri May 18 13:59:59 2007 UTC (12 years, 9 months ago) by redwards
Changes since 1.21: +149 -3 lines
Diff to previous 1.21
Rewritten gff2tab and updated FigGFF POD/methods
Sun Feb 5 00:45:19 2006 UTC (14 years ago) by overbeek
Diff to previous 1.20
RAE: Updating GFF files for extracting data from TIGR
Changes since 1.19: +17 -0 lines
Diff to previous 1.19
Added license words.
Wed Nov 2 21:56:33 2005 UTC (14 years, 3 months ago) by parrello
CVS Tags: caBIG-00-00-00
Changes since 1.18: +412 -412 lines
Diff to previous 1.18
Converted tabs to spaces.
Removed a redundant "my" that was causing a compiler warning.
Wed Oct 5 20:34:02 2005 UTC (14 years, 4 months ago) by overbeek
CVS Tags: caBIG-dataload-0
Diff to previous 1.17
fixes to update_uniq_id_data
Thu Sep 29 18:59:01 2005 UTC (14 years, 4 months ago) by efrank
Changes since 1.16: +12 -4 lines
Diff to previous 1.16
Fix:
   NCBI_NP:X maps to X, not NP_X since X already has NP_ init.
   change $type to lc($type) for everything not just a few
Add:
         NCBI_NM  <-> NM_ just like NP_
Wed Sep 28 17:02:34 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.15: +8 -4 lines
More gff2seed mods. Support translation of dbxrefs to seed aliases.
Fri Sep 16 22:12:04 2005 UTC (14 years, 5 months ago) by efrank
Changes since 1.14: +0 -2 lines
remove debug dumper printout
Fri Sep 16 22:05:47 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.13: +7 -0 lines
Handle the single-element-unescaped-attribute-bug.
Wed Aug 3 21:47:55 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.12: +1 -0 lines
Correcting seed2gff<->gff2seed
Fri Apr 29 20:48:51 2005 UTC (14 years, 9 months ago) by olson
Changes since 1.11: +18 -17 lines
Fix up format stuff.
Sun Apr 24 16:33:26 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.10: +30 -19 lines
minor changes to gff2seed/FigGFF
Thu Apr 21 16:28:21 2005 UTC (14 years, 10 months ago) by olson
Remove some debug prints.
Sat Apr 9 23:42:32 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.8: +3 -0 lines
gff2seed directory passes all checks
Sat Apr 9 21:09:30 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.7: +0 -3 lines
minor changes
Sat Apr 9 21:04:48 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.6: +27 -5 lines
initial commit of gff2seed to go from gff3 to seed directory
Sat Apr 9 17:21:15 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.5: +136 -5 lines
changes to seed_ctl and raelib
Fri Apr 8 20:22:23 2005 UTC (14 years, 10 months ago) by redwards
changed tag/value pairs completely. Ooops!
Wed Mar 30 20:49:24 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.3: +250 -48 lines
More gff fixes.
Thu Mar 17 20:02:40 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.2: +39 -31 lines
Change GFF format to only include cds features, and to attach the translation as a
key/value pair in the feature, with the translation itself in the FASTA section.
Tue Mar 15 19:47:15 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.1: +418 -46 lines
Update to GFF handling code. Parses GFF now.
Mon Mar 14 19:17:37 2005 UTC (14 years, 11 months ago) by olson
Add general-purpose GFF writing stuff.
