[Bio] / FigKernelPackages / FS_RAST.pm Repository:
Log of /FigKernelPackages/FS_RAST.pm
Mon Aug 30 02:22:52 2010 UTC (9 years, 5 months ago) by olson
CVS Tags: rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.30: +2 -1 lines
Diff to previous 1.30
re-redirect nap stdout to /dev/null. here's hoping it works on windows still
Fri Aug 27 19:23:32 2010 UTC (9 years, 5 months ago) by olson
Changes since 1.29: +2 -2 lines
Diff to previous 1.29
Change threshold
Mon Aug 23 18:33:11 2010 UTC (9 years, 6 months ago) by olson
CVS Tags: rast_rel_2010_0827
Changes since 1.28: +108 -24 lines
Diff to previous 1.28
More FS_RAST modes & supporting code for SAS use.
Sat Aug 21 15:49:45 2010 UTC (9 years, 6 months ago) by overbeek
Changes since 1.27: +0 -55 lines
Diff to previous 1.27
removing dependencies
Sat Aug 21 15:43:06 2010 UTC (9 years, 6 months ago) by overbeek
Changes since 1.26: +17 -16 lines
Diff to previous 1.26
Sat Aug 21 15:35:09 2010 UTC (9 years, 6 months ago) by overbeek
Changes since 1.25: +14 -3 lines
Diff to previous 1.25
fixed dependence on FIG.pm but not FIG_Config.pm
Sat Aug 21 00:30:33 2010 UTC (9 years, 6 months ago) by overbeek
Changes since 1.24: +1 -1 lines
Diff to previous 1.24
nasty bug in frameshift correction
Fri Apr 3 00:20:32 2009 UTC (10 years, 10 months ago) by overbeek
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.23: +136 -32 lines
Diff to previous 1.23
force frameshifts to be of longer chunks
Tue Mar 24 17:01:53 2009 UTC (10 years, 11 months ago) by overbeek
CVS Tags: rast_rel_2009_03_26
Diff to previous 1.22
fix to get rid of undefined value
Thu Feb 5 14:33:02 2009 UTC (11 years ago) by overbeek
Changes since 1.21: +37 -33 lines
Diff to previous 1.21
fix contraints on gluing pieces
Wed Feb 4 01:46:36 2009 UTC (11 years ago) by overbeek
CVS Tags: rast_rel_2009_02_05
Changes since 1.20: +27 -5 lines
Diff to previous 1.20
fixes to seeing if two pieces can be glued together
Sun Feb 1 21:05:11 2009 UTC (11 years ago) by overbeek
Changes since 1.19: +6 -6 lines
Diff to previous 1.19
it will catch more now
Sun Oct 19 23:52:51 2008 UTC (11 years, 4 months ago) by overbeek
Changes since 1.18: +43 -6 lines
Diff to previous 1.18
fixes to detecting consistent fragments
Fri Sep 12 01:47:15 2008 UTC (11 years, 5 months ago) by overbeek
Changes since 1.17: +2 -2 lines
Diff to previous 1.17
fixes to FIGV.pm, CompareMR.pm and FIG.pm to support comparison of metabolic reconstructions
Sat Jul 5 15:53:08 2008 UTC (11 years, 7 months ago) by overbeek
Changes since 1.16: +68 -9 lines
Diff to previous 1.16
fixes to grouping
Sun Jun 15 13:43:00 2008 UTC (11 years, 8 months ago) by overbeek
Changes since 1.15: +67 -8 lines
fix to computing locations for frameshifts
Thu Jun 12 21:42:00 2008 UTC (11 years, 8 months ago) by overbeek
Changes since 1.14: +6 -6 lines
enlarge the fragment of DNA in which a hit is sought
Tue Jun 3 12:27:41 2008 UTC (11 years, 8 months ago) by overbeek
Changes since 1.13: +12 -5 lines
minor fixes relating to translation code
Tue Jun 3 12:22:24 2008 UTC (11 years, 8 months ago) by overbeek
Changes since 1.12: +43 -2 lines
fix clean_span - it assumed positive strand
Wed Feb 13 15:21:41 2008 UTC (12 years ago) by overbeek
CVS Tags: rast_rel_2008_04_23
clean up name conflicts
Sat Feb 9 14:05:06 2008 UTC (12 years ago) by overbeek
Changes since 1.10: +15 -2 lines
fixes for nonstandard genetic code
Sat Feb 9 02:02:51 2008 UTC (12 years ago) by overbeek
Changes since 1.9: +9 -2 lines
fixes to FS_RAST.pm to handle nonstandard genetic codes
Sat Jan 5 15:35:52 2008 UTC (12 years, 1 month ago) by overbeek
Changes since 1.8: +2 -2 lines
additions to FIGfam maintenance
Tue Dec 18 14:12:56 2007 UTC (12 years, 2 months ago) by overbeek
Changes since 1.7: +3 -3 lines
require valid starts and stops for frameshift correction
Sun Dec 16 03:55:43 2007 UTC (12 years, 2 months ago) by overbeek
Changes since 1.6: +103 -70 lines
fixes to frameshift correction
Sat Dec 8 23:27:10 2007 UTC (12 years, 2 months ago) by overbeek
remove trailing stop codon from translation
Sat Dec 8 21:20:41 2007 UTC (12 years, 2 months ago) by overbeek
Changes since 1.4: +64 -20 lines
fixes to FS_RAST.pm for frameshift detection
Mon Dec 3 18:42:17 2007 UTC (12 years, 2 months ago) by overbeek
fix reference to nap in FS_RAST.pm
Sun Dec 2 18:41:53 2007 UTC (12 years, 2 months ago) by overbeek
Changes since 1.2: +7 -0 lines
fixes to add an extra alignment
Wed Nov 21 20:41:05 2007 UTC (12 years, 3 months ago) by overbeek
Changes since 1.1: +150 -54 lines
add code to fix frameshifts in a genome
Wed Nov 21 13:36:05 2007 UTC (12 years, 3 months ago) by overbeek
add FS_RAST.pm, a module to support RAST searches correcting frameshifts
