[Bio] / FigKernelPackages / FIGjs.pm Repository:
Log of /FigKernelPackages/FIGjs.pm
Wed Sep 3 20:30:22 2008 UTC (11 years, 2 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Fixed URL references.
Tue Sep 26 13:35:44 2006 UTC (13 years, 1 month ago) by parrello
Fixed a missing equal sign in the generated HTML.
Thu Jan 26 20:12:39 2006 UTC (13 years, 9 months ago) by golsen
Changes since 1.12: +8 -5 lines
Fixed a reversal of single and double quotes in the tooltips pop-up.
Mon Dec 5 19:06:30 2005 UTC (13 years, 11 months ago) by olson
Changes since 1.11: +17 -0 lines
Added license words.
Wed Nov 23 20:34:59 2005 UTC (13 years, 11 months ago) by overbeek
Changes since 1.10: +33 -7 lines
major changes to attributes and protein families. There are changes to several modules to deal with new attributes database, and simultaneous updates to protein families
Sat Jul 30 20:22:05 2005 UTC (14 years, 3 months ago) by golsen
Changes since 1.9: +35 -22 lines
Do some cleanup, and covert to relative URL for the javascript libraray.
Fri Jul 22 21:50:44 2005 UTC (14 years, 3 months ago) by overbeek
minor tweaks by Rob to make nmpdr work
Fri Jul 22 14:43:08 2005 UTC (14 years, 3 months ago) by overbeek
Fix <script> tags in a way that makes IE happy. (Bob)
Fri Jul 22 12:33:40 2005 UTC (14 years, 3 months ago) by overbeek
Changes since 1.6: +3 -1 lines
Maje the toolTipScript method return a javascript <script> tag to include the javascript code.
Wed Jun 29 04:33:02 2005 UTC (14 years, 4 months ago) by redwards
CVS Tags: merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
Changes since 1.5: +6 -322 lines
Changes to javascript to externalize everything into FIG.js and clean up the code
Mon Mar 14 17:12:16 2005 UTC (14 years, 8 months ago) by redwards
CVS Tags: Root-bobdev_news, merge-bobdev_news-1, merge-trunktag-bobdev_news-1
Changes since 1.4: +4 -1 lines
real fix to javascript
Mon Mar 14 17:08:30 2005 UTC (14 years, 8 months ago) by redwards
fix to javascript
Fri Dec 17 14:54:45 2004 UTC (14 years, 10 months ago) by heiko
Changes since 1.2: +47 -41 lines
tooltip code will be ignore if internet explorer on
mac is used. workaround because of total crashes with that browser
Thu Nov 11 04:22:48 2004 UTC (15 years ago) by olson
Changes since 1.1: +30 -3 lines
GenDB changes.
Fri Oct 22 17:04:36 2004 UTC (15 years ago) by heiko
some jvascript methods
that produce tooltips
may be used in chromosomal_clusters.cgi
