[Bio] / FigKernelPackages / FIGgjo.pm Repository:
Log of /FigKernelPackages/FIGgjo.pm
Thu Apr 12 04:06:45 2007 UTC (12 years, 10 months ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_release_2008_09_29
Changes since 1.2: +23 -8 lines
Improve handling of multidomain query sequences in coloring of sims
matches (do not include white, and fade all colors in the case of a
perfect match).
Thu Apr 12 02:13:37 2007 UTC (12 years, 10 months ago) by golsen
Changes since 1.1: +71 -35 lines
Alter the display of functions in the protein similarities page so that
role separated by / are displayed side-by-side.
Thu Apr 12 00:47:54 2007 UTC (12 years, 10 months ago) by golsen
Change the coloring of functions in the protein page similarities table,
and the fid_checked page phylogenetic tree to match the individual roles,
rather than the function as a whole.  This will give features with multiple
roles separate colores for each role.  It will also make assignments with
different comments match, so long as the role is the same.
(Also added another pallet with more colors.)
