[Bio] / FigKernelPackages / FIG_CGI.pm Repository:
Log of /FigKernelPackages/FIG_CGI.pm
Links to rast_rel_2008_09_29: (view) (download) (as text) (annotate)
Thu Jun 26 21:11:11 2008 UTC (11 years, 7 months ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.10: +26 -17 lines
Add annotation support to FIGV. Add FIGM.
Fri May 16 08:29:40 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.9: +3 -0 lines
Added a hook to log robot activity.
Tue Apr 29 05:30:45 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.8: +5 -11 lines
Enhanced to be compatible with cookie-based environment configuration.
Tue Feb 5 01:13:01 2008 UTC (12 years ago) by parrello
CVS Tags: rast_rel_2008_04_23
Fixed a POD error.
Thu Dec 6 13:48:11 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.6: +8 -8 lines
Wed Nov 29 15:19:19 2006 UTC (13 years, 2 months ago) by olson
Changes since 1.5: +21 -1 lines
Rollup commit of 48hr changes.
Added add_virtual_genome to Subsystem.pm to support UnvSubsys doing
the right thing when handed a FIGV.
Added propagation of 48hr_job thru the various link generation scripts in order for protein.cgi/display_subsys.cgi
to properly show virtual genomes.
Sat Aug 5 03:10:01 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.4: +0 -24 lines
Fixed a duplicated method.
Fri Jul 28 02:00:32 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.3: +133 -43 lines
Added some comments and an "is_sprout" method.
Added license words.
Thu Nov 3 22:13:18 2005 UTC (14 years, 3 months ago) by olson
CVS Tags: caBIG-00-00-00
remove debug warns
Mon Oct 31 21:09:56 2005 UTC (14 years, 3 months ago) by olson
FIG/CGI wrapper code.
