[Bio] / FigKernelPackages / FIGStatisticalModels.pm Repository:
Log of /FigKernelPackages/FIGStatisticalModels.pm
Tue Nov 7 17:18:47 2006 UTC (13 years, 3 months ago) by redwards
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_release_2008_09_29
fixing log error
Sat Oct 28 17:55:57 2006 UTC (13 years, 3 months ago) by redwards
Changes since 1.4: +102 -2 lines
more statistics
Mon Oct 9 21:18:29 2006 UTC (13 years, 4 months ago) by redwards
Changes since 1.3: +10010 -10007 lines
updating new matrices and coeffs
Tue Aug 8 22:19:37 2006 UTC (13 years, 6 months ago) by overbeek
Changes since 1.2: +8 -3 lines
RAE: updating IFC/DFC
Mon Aug 7 23:08:56 2006 UTC (13 years, 6 months ago) by overbeek
Changes since 1.1: +9 -7 lines
RAE: updating mcaulliffe scoring system
Sun Jul 23 01:01:14 2006 UTC (13 years, 7 months ago) by overbeek
RAE: More direct and indirect functional coupling scores
